hi every one
I have a 3c mk111 with leaking rams I'm looking for new seals CHEAP
Can any one tell me if the main seal re (number off seal ) sm262200-axs theres also polypac se lemaster. are these the same seal for all the 2" ram's ?
Are these seals ok for bio degradeable oil or will they degrade
cheers
Mick
wotcha I'm after new seals
- Real name: Mark Rive
- Has thanked: 33 times
- Been thanked: 26 times
Re: wotcha I'm after new seals
Hi Mick, welcome on board For me here in Guernsey I've found Diggerparts.net the cheapest including the postage, and they use paypal which saves a lot of hassle. If you let me know which seals you need I'll get you the JCB part numbers. For info just got a bucket ram seal kit for a 3DIII, It was a tad over 10 quid delivered. Which I thought was good, no doubt someone will be along in a minute and tell us they can get them for a fiver Cheers Mark
- Real name: morgan smith
- Has thanked: 44 times
- Been thanked: 13 times
mark, thats cheap! I'm using the old period chevron seals for my JCB 3 and they worked out far more expensive but the seals mick needs will be seal master, easy to locate!
- Real name: Julian
I don't know if there's anything special about JCB stuff or if they use generic seals. I did the seals on a ram on my digger a few years ago and just got them from HTS in Manchester http://www.a.andywhiteheadgallery.co.uk/about%20us.html They just measured them up - ram seals, PTFE backing rings, dust seals, bronze rubbing bushes etc and fetched them off the shelf. Not an expensive exercise, contrary to what I was expecting!
HTS has a 'girl' at the trade counter who is worth her weight in gold
Julian.
Julian.
Topic author - Posts: 7
- Real name: mick
nice one lads
I rang digger parts and need to wait for a call back, my local engineering supplier quoted me just under £12 each but of course thats just one seal. I have a parts book yet theres no flipping part numbers in it !!
So mark could you check the main seal part number to see if its the same on all the rams
my tractor number is 200258715
I'm not sure which year I think it's 1976
the thing is pretty good just scabs of rust
cheers
Mick
cheers
Mick
mickmtb wrote:nice one lads
cheers
Mick
I've found the quickest way is to fill out their on-line form, I did that one Wednesday night at around 8.00pm and got a reply straight back, with price etc. With regards to the seals, they are not the same on all the rams!
Right no messing here's all the info you will ever need. If you use the JCB P/No:they will cross reference, the kits are complete and good quality PS I dont work for them etc etc Mark
- Real name: Adam Carter
The lovely lady at HTS is Sally, known her for many years.
Here is some more information on the seal kits required for the JCB 3C mk3.
- Real name: mick
mark quote I've found the quickest way is to fill out their on-line form, I did that one Wednesday night at around 8.00pm and got a reply straight back, with price etc. With regards to the seals, they are not the same on all the rams!
Right no messing here's all the info you will ever need. If you use the JCB P/No:they will cross reference, the kits are complete and good quality PS I dont work for them etc etc Mark[/quote]
hi mark
hey that's a very handy list, looks like every one else thinks so as well.
dave from digger parts rang me back
he only had one set that he said was for mine pt 991/00003 but had another three sets pn 991/0004 the center seals are the same re 2" ram just cylinder size of 4-1/2" instead of 4" so I can use some of the seals from the sets. digger parts dont have any thing else re ram seal's kits for my 3c mk111 it cost me £58 with post for the four sets, which I was happy with that he also gave me two contacts for other bits.
If the weather's not to bad in the morning I'll get the back hoe rams off one has the cap welded ffs so got to grind that weld off and hope its not been threaded
cheers
Mick
hi mark
cheers
Mick
