Here's a question for you...
If a 12v negative earth system is using the dash board tell-tail bulb for the exciter line, what would happen if I upgrade the bulb for an led equivalent to make it brighter, remembering the led will only allow current to travel one way.
All opinions, including sniggering, welcomed!
Alternator tell-tail light conundrum
- Has thanked: 854 times
- Been thanked: 697 times
Re: Alternator tell-tail light conundrum
https://electronics.stackexchange.com/q ... p-with-led
Looks like there are confusions out there!
- Real name: ian
- Has thanked: 126 times
- Been thanked: 117 times
The lamp only needs to pass current one way, so the fact it's a diode isn't the problem.
The problem is that it requires so little current to light an LED, it won't excite the alternator.
If you use 2W LED, it will excite the alternator and there is little chance you'll be able to ignore it.
Edit:
For reference, 2W is about right - (it's not just a random number)
Edit:
Topic author - Posts: 1004
- Real name: Rob
- Has thanked: 206 times
- Been thanked: 284 times
Thanks for the insights, I think I'm leaning towards the 'leave well alone' verdict for the moment as this machine needs lots of other things done as well.
Cheers.
Cheers.
I have a similar issue with 2 agricultural trailers with led lights. There is not enough draw on the indicator circuits to light the trailer warning light on the tractor dash.
- Real name: Rob
If the trailers are new they should have been fitted with resistors in the system to correct the draw. You get similar issues with can-bus cars and led trailers.
hair bear wrote:If the trailers are new they should have been fitted with resistors in the system to correct the draw. You get similar issues with can-bus cars and led trailers.
Not new but fitted from new.
- Real name: Tim
- Has thanked: 191 times
essexpete wrote:I have a similar issue with 2 agricultural trailers with led lights. There is not enough draw on the indicator circuits to light the trailer warning light on the tractor dash.
You can get flasher relays designed to run LED's for just this situation
Slooby wrote:essexpete wrote:I have a similar issue with 2 agricultural trailers with led lights. There is not enough draw on the indicator circuits to light the trailer warning light on the tractor dash.
How and where to fit?
- Real name: Tim
essexpete wrote:How and where to fit?
You replace the stock flasher relay with one like this:
https://www.ebay.co.uk/itm/272665874287 ... media=COPY
