3CX JCB 1997 Maint. questions
gecko.cx
Real name: ian
Has thanked: 126 times
Been thanked: 117 times
Re: 3CX JCB 1997 Maint. questions
Post #11 by gecko.cx » Fri Nov 05, 2021 12:31 pm
Hi Norm,
Short answer - the slew box was overflowing - only explanation I could come up with was one seal was leaking hydraulic fluid into the box.
As you can see, the contents of the box looked like a mix of mud, rust and grease, so I took the opportunity to clean it out.
gecko.cx
Real name: ian
Post #12 by gecko.cx » Sun Sep 04, 2022 6:05 pm
A question for anyone with a P8.
I recently burst a steering ram hose, so decided to replace all the hoses in that area.
I've got spec's for all the hoses but one. It's the low pressure return line (3/4", 80 bar) - No. 11 on the drawing, PtNo. 632/30300.
So I'm wondering if anyone knows how long this hose should be (currently in the wrong country to measure my own).
gecko.cx
Real name: ian
Post #13 by gecko.cx » Thu Sep 08, 2022 5:37 am
just a follow up - I haven't manage to determine the correct length, so scaling from the drawing above, I took a guess at 800mm.
It's the return line, hence the low 80 bar rating. My hose maker apparently didn't have low pressure hose, so made it with 860 Bar hose instead.
I just hope I can bend the curve into it!
Has thanked: 854 times
Been thanked: 697 times
Post #14 by essexpete » Thu Sep 08, 2022 5:12 pm
You could have another short section made up with a coupler just in case?
gecko.cx
Real name: ian
Post #15 by gecko.cx » Sun Jan 29, 2023 3:41 am
My boom ram has had in internal leak for some time. Despite having the seal kit on hand, I've been happily ignoring it.
Now the rod seal has sprung a leak which it rather forcing the issue.
My question: is it possible to extract the boom ram without disassembling the boom from the king post?
agrimax
Real name: R
Has thanked: 14 times
Been thanked: 192 times
Post #16 by agrimax » Sun Jan 29, 2023 9:34 am
Stretch the boom and dipper out behind and remove the rod pin first.Then pull the rod in before removing the hoses and then the cylinder pin and then lift out the ram.
gecko.cx
Real name: ian
Post #17 by gecko.cx » Sun Jan 29, 2023 3:07 pm
Thanks.
looking at it (while all assembled), it looks like the boom would have to be at 90° or it'd end up going through the back window.
mechman
Real name: norman orrick
Has thanked: 149 times
Been thanked: 136 times
Post #18 by mechman » Sun Jan 29, 2023 7:57 pm
gecko.cx
Done mine recently, the only awkward part was the refusal of the king post pin to co-operate. otherwise pretty straight forward. Set the boom horizontal (rested mine on a wooden prop) and as said remove rod pin first, retract rod then hoses etc. There are some pics on my posts, title is stuck pin. Keep us informed.
Norm.
gecko.cx
Real name: ian
Post #19 by gecko.cx » Tue Jun 27, 2023 2:43 pm
Hi All, it took a while, mostly due to the rod being bent making it damn near impossible to undo the gland nut.
After severely bending my stilsons in a failed attempt, I drew up a ring spanner and sent it to a laser cutter (ordered a spare to be sure).
Once the rod had been straightened, the cylinder went together fine
Getting the cylinder eye pined in place took some ingenuity!
The machine is back together and working well.
Has thanked: 1889 times
Been thanked: 1705 times
Post #20 by Jeremy Rowland » Tue Jun 27, 2023 9:12 pm
Homemade tools can make an awful lot of sense and a hard job a lot easier. :thumbup:
Users browsing this forum: Bing [Bot] and 14 guests
