3c3 build 5 rear axle brake assembly
ehannon
Real name: e hannon
Has thanked: 2 times
Post #1 by ehannon » Wed Jan 25, 2023 10:58 am
Hi there,
A build 5 powertrain - is there a rear axle internal brake slave cylinder fitted?
I'm loosing fluid on one side and its not the master cylinder.
I'm hoping that it is a slave cylinder that i can change as opposed to a big axle job!
Many thanks
Has thanked: 854 times
Been thanked: 697 times
Re: 3c3 build 5 rear axle brake assembly
Post #2 by essexpete » Wed Jan 25, 2023 11:13 am
There might be a workshop or parts manual that would include that axle on here under the slightly later early 3CX. We never had to touch the brakes on ours but the brake unit is in a separate housing from the main axle trumpet. My guess is if there is no obvious leak, then the internal piston seal will be leaking.
BTW don't use ordinary brake fluid in the system.
ehannon
Real name: e hannon
Post #3 by ehannon » Wed Jan 25, 2023 1:01 pm
Ok thanks for that pete.
Im hoping that the slave cylinder is external and it can be easily changed. Yes, im using mineral brake fluid, thanks
dixie-normous
Real name: john
Has thanked: 16 times
Been thanked: 56 times
Post #4 by dixie-normous » Wed Jan 25, 2023 8:37 pm
Not sure of the properties of mineral brake fluid but i'm pretty sure the 3C3 uses hydraulic oil in the brakes, mine has a sticker on the dash saying to only use it
Post #5 by essexpete » Wed Jan 25, 2023 9:28 pm
dixie-normous wrote:Not sure of the properties of mineral brake fluid but i'm pretty sure the 3C3 uses hydraulic oil in the brakes, mine has a sticker on the dash saying to only use it
Yes I am sure that is what was used in our build 5 but the LHM type might be OK?
agrimax
Real name: R
Has thanked: 14 times
Been thanked: 192 times
Post #6 by agrimax » Thu Jan 26, 2023 2:05 am
Earlier build 5s had dry brakes.The last of them had oil immersed discs. If yours has dry,it will have slave cylinders on the top of the brake housings.JCB part no. 15/103600 for the cylinder or 15/103601 for a seal kit. Not so sure if the cylinder is still available though.Possibly superseeded...
If you have wet brakes,there are no outer slave cylinders,just an internal piston with a seal. Pt no. of the seal...813/00184.
10w light hydraulic oil or LHM fluid is the recommended stuff...
Post #7 by essexpete » Thu Jan 26, 2023 10:33 am
agrimax wrote:Earlier build 5s had dry brakes.The last of them had oil immersed discs. If yours has dry,it will have slave cylinders on the top of the brake housings.JCB part no. 15/103600 for the cylinder or 15/103601 for a seal kit. Not so sure if the cylinder is still available though.Possibly superseeded...
I had forgotten that, our wet brake had holes in the cab mat for the early dry brake adjusters. The dry brake set up must have been short-lived. We had a T reg here with a Brockhouse and our own build 5 was a V reg early 1980.
ehannon
Real name: e hannon
Post #8 by ehannon » Thu Jan 26, 2023 11:28 am
Thanks for the information and part numbers - much appreciated.
Checked yesterday, my build 5 axle has wet brakes with no external slave cylinder - It has a large internal seal that is a much bigger job to do.
I will keep checking over it - hopefully it is something else before i have to go at the axle.
thanks again.
