Some good looking photos there Patrick , whats the go with axle in the middle of the trailer ???? must get a fair bit of tyre scrub there or does it steer ???
or perhaps lift ?? also looks like the trailer extends as well sure is a Swiss army knife of floats (trailers) you are using
V. D. Vlist
- Real name: Paul Griffiths
- Has thanked: 384 times
- Been thanked: 256 times
- Real name: Patrick
- Has thanked: 88 times
- Been thanked: 89 times
Re: V. D. Vlist
Mrsmackpaul wrote:Some good looking photos there Patrick , whats the go with axle in the middle of the trailer ???? must get a fair bit of tyre scrub there or does it steer ???
Nowt wrong with your eyes mate it does indeed extend, not all that long, 3m is max.
And that first axle, well sometimes it comes in handy, most of the times though it's not all that convenient... it does steer (to a certain amount of degrees) and it does lift, but ground clearance isn't that great, so I actually have to lift the suspension of the tractor as well to avoid "rubber scraping"...
These trailers were a bit French designed like, because of that first axle you can take on (legally) 45t loads, otherwise it would have been just 40t...
Empty weight isn't that brilliant though (26t), it's about the same as the old DAF with the 5 axled semi (28t), rumor has it that these trailers are going to be replaced by the new Nooteboom Manoovr (odd spelling isn't it...).
Cheers, Patrick
Re: V. D. Vlist
Have been going back and forth for the past two weeks from Tournai (Belgium) to Liancourt ( northern France) with windmill sections.
Cheers, Patrick
Cheers, Patrick
Re: V. D. Vlist
Following pic's are from a job at Liverpool docks, one of the scrapyard cranes was being disassembled for transport to Holland, things didn't go that easy though, took the crew a bit longer then suspected...
Cheers, Patrick
Cheers, Patrick
- Has thanked: 1889 times
- Been thanked: 1705 times
Re: V. D. Vlist
pv83 wrote:Seems that the following order of the pic's is a bit "shook up" like, but you'll get the idea hopefully...
Great pics Patrick thanks for sharing
Re: V. D. Vlist
I take it looking at the photos these cranes ( the ones you are shifting ) are on tracks ?? or maybe Im not seeing that right
great photo's and even looks like it maybe a sandy beach at your work site ?
Re: V. D. Vlist
Mrsmackpaul wrote:I take it looking at the photos these cranes ( the ones you are shifting ) are on tracks ?? or maybe Im not seeing that right
Aye, they were on tracks Paul, nowt wrong with your eyes mate! Some smaller parts along with the tracks were loaded upon normal flatbeds.
Can't remember what make the crane was, probably Sennebogen...
Wouldn't go near that "beach" though if you would see another day...
