JCB 801 boiling batteries
Bivvysenior
Real name: Rom Swiokla
Re: JCB 801 boiling batteries
Post #11 by Bivvysenior » Wed Apr 29, 2015 6:28 pm
Latest.
Replaced alternator every thing was fine, when I put everything back together the light was back on.....
Took it apart found I broke the L wire connectiion on connector block side on loom when refitting obviously its was brittle.
Anyone got any ideas where to buy a new replacement connector ?
Tried JCB but you have to buy a new loom!!!!!!
Almost there...........
Mrsmackpaul
Real name: Paul Griffiths
Has thanked: 384 times
Been thanked: 256 times
Post #12 by Mrsmackpaul » Wed Apr 29, 2015 9:37 pm
I gather your alternator looks like one of these sought of with the two spade connectors at right angles if so you can just cut both the wires of and put two spade connector plugs on
Bivvysenior
Post #13 by Bivvysenior » Wed Apr 29, 2015 10:16 pm
My alternator has 3 connections , but if icannot find the correct plug I will take up your suggestion
Many thanks Paul for the idea
Bivvysenior
Post #14 by Bivvysenior » Tue May 05, 2015 11:49 pm
Managed to find replacement female connectors on ebay for a couple of pounds and replaced them in old plug . things are now sorted and no boiling battery as voltage now does not exceed 14.6v when charging....
Mrsmackpaul
Post #15 by Mrsmackpaul » Wed May 06, 2015 5:28 am
Job done another happy customer lol
good to hear it's all sorted and you get back to living the dream
Bivvysenior
Post #16 by Bivvysenior » Sat Aug 22, 2015 7:34 pm
Sorry for late conclusion.
The alternator replaced cured the problem thank you all for the helpful advice.
Has thanked: 1889 times
Been thanked: 1705 times
Post #17 by Jeremy Rowland » Sat Aug 22, 2015 8:09 pm
Glad you got it sorted. :thumbup:
