Need advise on painting a model
Topic author - Posts: 467
- Real name: Geraint Jones
- Has thanked: 5 times
- Been thanked: 6 times
Hello, I'm going to repaint a model. I've stripped the old paint and I have the primer and top coat ready to go. My question is whats the best way to clean and prepare the surface so the primer will take, the model is diecast. Thanks.
- Real name: martyn henley
- Has thanked: 38 times
- Been thanked: 50 times
Re: Need advise on painting a model
Hi Geraint, no work on the railway today ? right, try wire wool or a small wire brush... you could even sand it all over if possible as there could be blemishes, normally die cast's are painted by baking the paint on and that seems to cover any blemishes .. you might even have to use an etched primer for your paint to stick to the surface ... if any one else has any other suggestions
- Real name: Tracshovel
- Has thanked: 142 times
- Been thanked: 36 times
Just make sure all the parts are very clean. Use some of those thin rubber gloves to keep greasy fingermarks off. Wire wool the parts and wipe/blow clean or even wash with bicarbonate soda & water.
Next part is the painting.
Easiest is to use Halfords/Hycote acryilic paints if you can match the colour or you can use the Halfords primer which will take most types of single pack paint on top. This paint is pretty forgiving and easy to use. If using car paints you may need an etch primer to make it stick to the diecast.
When painting, do it in light coats and build up the layers (don't be tempted to blast it all on in one go). also do it in a dry warm room and a dust free area. You can use a hot air blower (wifes hairdryer works best ) to help warm the parts before and during painting (also warm the paint can up and shake well before use).
Hang your parts on a rail with brass wire so you paint lots of the small ones quickly and easily.
Lets see some pictures of your progress
Looking forward to seeing your work I guess it is very easy to put on too much paint that would cover up the fine detail.I used to use an airbrush and many thin coats of paint.Last model paint job I did was on an AMT D8,I used Caterpillar yellow in a spray can.It turned out better than I thought it would.
- Real name: graham barnewall
Great tips there Tracshovel,I have done a few repaints myself but to be honest never got them 100% first time,and never completely 100% happy,what I suffer from most is lack of patience
- Has thanked: 1889 times
- Been thanked: 1705 times
gbarnewall wrote:Great tips there Tracshovel,I have done a few repaints myself but to be honest never got them 100% first time,and never completely 100% happy,what I suffer from most is lack of patience
Yes Graham my problem too patience is for people who like waiting
Jeremy Rowland wrote:gbarnewall wrote:Great tips there Tracshovel,I have done a few repaints myself but to be honest never got them 100% first time,and never completely 100% happy,what I suffer from most is lack of patience
Spot on Jeremy,we can have all the time we want to wait when we're dead ,
I can't wait now for the summer to arrive,just to enjoy the paint as it bakes on in the sun,I have used celulose paint and in RAL5015 it just looks amazing,so so deep and lush
