Taken earlier this year, a new 950H that appears to be missing something, can anyone see what..........
SB
Cat 950H missing something?
Topic author - Posts: 1247
- Real name: Stu Bickley
- Has thanked: 70 times
- Been thanked: 116 times
- Real name: graham
Re: Cat 950H missing something?
no its the radio ,the pikes have been round
this 950 is was being converted into a Waste Handler Plus.
Loader frame fabricated in house to give higher load over heights into Waste Bulkers.
SB
SB
- Been thanked: 3 times
If you look at the second picture and imagine the front is the back it looks like a mighty alternative to the JCB fastrac
"A man reaps what he sows"
What kind of lifting capacity is left like this?
Why not go with a high tip bucket setup instead?
Keeps the base machine unmodified which could be plus if it has breakdowns, just hook the bcuket to another machine and continue loading.
/Per Eriksson
Cat tech
Cat tech
Lifting capacity remains unchanged, no additional counterweight is needed, it is based on a high lift machine out the factory. The loader frame is dissasembled and the torque tube re-used in the new fabrication.
We do use high tip buckets, but these are right on the limit of height and whilst they can tip into the trailer they cannot push down and compact the trash inside.
This Hilift + is availiable with standard bucket of hi tip also.
SB
SB
