A couple of photos of dipstick,filler and final drive plug.Could not take photos of the other filler level check items as the machine was undergoing a respray.
International 100b series 2 loader Help
Re: International 100b series 2 loader Help
Topic author - Posts: 27
- Real name: Warren
Hello eytee and b100worker,seems there are differences in the models because i have only 1 drain for transmission.
I have drained and refilled my trans twice now and the oil is cleaner but needs more changes,its moving off the mark faster but
has a way to go before it will be useful, and there seems to be a lot of air getting into the system that i haven't tracked down as yet.
Hope your project goes well for you as i reckon they would a handy little machine when working properly.
And your right about the American machines they seem to be totally different probably only share the name International.
If you are still getting air in the system you need to first check all the connections,hoses and filter/strainer seals are good.If Ok,you will need to bleed the system on the cooler,remove front grill,you will se the bleed screw on the cooler.Move machine back and forth a few times and re bleed if still slow.
- Real name: Warren
OK thanks Martyn,I have cleaned the suction filter but didn't have seals to fit so i will have to dismantle again later,
Have looked for air entry but haven't located it yet just trial and error i guess,if all else fails i might try to pressurize with compressed air
And then check for leaks with soapy water.
Filled the gearbox with clean oil today (recieved ribbing that I had doubled its vallue) ran the engine with bleed screw open and drive was restored then the geezer erupted from the bleed screw, didnt dampen my mood
Next step is sort electrics, start solenoid is stuffed needs replacing (and spares available/suppliers) connect and test gauges.
- Real name: Warren
Good one Eytee sounds like you have transmission pressure,I am still trying to get the oil clean in mine on the third change now and its getting better, I am unsure of my pressures because the gauge went missing sometime one or two owners ago.
I have electrical problems also but focusing on transmission and oil leaks in hydraulic lines and track adjusters seals.
did a search found camara film, fishing reel, bras but no drott
ebay uk is rife with them
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180557705527&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330470331121&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200516603271&ssPageName=STRK:MEWAX:IT
almost room to export them
eyetee wrote:did a search found camara film, fishing reel, bras but no drott
[color=#804080]
Erm.. probably cause I bought it .. good nick , runs well and being delivered tommorrow.
