Struggling to find the correct seal kit for the cylinder
I have fitted the rod seals part number 991/00003 they fit fine but the cylinder seal kit that came with it part number 2411/4009 does not fit ? Does anyone know the correct number i should be trying to get,they are old leather type seals for a 100mm cylinder.
JCB 3 1966 CYLINDER SEALS HELP REQUIRED
Topic author - Posts: 4
- Real name: stewart
- Real name: phil wheelton
Re: JCB 3 1966 CYLINDER SEALS HELP REQUIRED
Which ram are you working on and do you have the rod and cylinder size's
I managed to get matched seals for my machines from a Cardiff supplier, called Seal master, they were good quality and not a bad price.They supplied everything including scraper seal.
Phil the rod is 50mm,the cylinder is 100mm,I have done the rod seal thats all fine.
This is a picture of the current seals
another picture of seals only
- Real name: morgan smith
- Has thanked: 44 times
- Been thanked: 13 times
hi there!, this seal type is called 'Chevron seals' and tha size is 3 5/8 inch bore, Manchester seals 01618327922 have these in stock! or at least they did last summer when I resealed the rams on my jcb 3! ask for sally she is very switched on!
