I have had a lot of calls and emails regarding replacement of glowplugs on BD264 engines. Conversion kits have been available for some time.The original plugs are hard to get hold of and also expensive.The original plugs were wired in series with a resistor,this dropped the voltage to around 6 volts. Some people have made the mistake of putting battery voltage straight to the plugs to test them and not using the resistor,damaging the glowplugs.
The conversion kit is simple to fit and will give more heat than the original making engine starting from cold much better.
Photo shows the adaptor and glowplug,this screws into the body of the injector holder that once held the original glowplug.The kit comes with all the bridgeing cables and instructions.
The cost of the kit is around £150,it also fits the BD281 engines
Glowplug replacement for I H BD264 and 281 engines
Topic author - Posts: 6393
- Real name: graham
- Has thanked: 97 times
- Been thanked: 74 times
Re: Glowplug replacement for I H BD264 and 281 engines
where is the best place to get these ,as one of my bosses has just got a BTD6 that the glow plugs now do not work on it after they tested them
This chap used to supply them Graham robert@machinery.uk.com
Or try http://www.forge-services.co.uk/cgi-bin/mf000001.pl?ACTION=SHOWFORM
FS63291 Glow Plug Conversion Kit - BD264/281, B450
Models:
BD264/281, B450 etc.
OEM Numbers:
This Kit replaces the original 4 x 3109742R1 9 Volt plugs and sleeves and converts the engine to economical and easily available 12 Volt plugs and no longer requires the heater plug indicator which has to be wired out of circuit.
Kit consists of 4 plugs and 4 sleeves.
Plug 0400 226 129 11.5V
Price: £130.00
£156.00 Including VAT at 20%
Models:
OEM Numbers:
Price: £130.00
- Real name: Julian
- Been thanked: 13 times
Are the originals the same as Series Landrover:
http://www.hollandrover.co.uk/heater-glow-plugs-568335-set-of-4-land-rover-series-1-2-2a-3-33-p.asp
These are not that expensive.
Julian.
Julian.
- Real name: Jan
Glowplug replacement for IH BD264 and 281 engines New Run GREAT
This subjekt is really interesting since someone over here has a real good solution for this problem.He produced new ones.....
The Landrover don't work because tread isn't OK.
I already tried this.
Over here in Holland I med a guy on a swap meeting who has connections with an German automotive company wich has on it's turn some important connections with BERU .He ordered for the Dutch market 320 pieces glow plugs (That would be 80 Farmall Super BMD's or B-450 or any machine with BD-264 engine) for Farmall with this particular engine on special order at the factory.Also the great quality of BERU he told me.He says the kits available on market is bad quality plug and silly adaptor.He owns 3 Farmall's with BD-264 engine.So for himself it was OK and the the rest he sells away.320 was minimum run number for productionrun.He told me he already sold to England and Australia.That could be the reason for special production batch for market wich requires........
Its a a real strange glow plug to see but fits perfect since last summer imounted.Doesn't look like the picture above posted already and no adaptor required.Only the original mounting nut.It also really long 13cm total length.
He lives in east Netherlands.Speaks English very well.He also sells tractor gauges of real good quality for Farmall and many other brands.Not available in England by suppliers....
My Farmall SBMD runs and start as never before did unbelivable.I can recommend this fellow for sure.Cost arounds 160 Euro to me but worth it for sure.
Maybe a good message and for you it's helpfull.
Thanks from Jan
Netherlands
1955 Super BMD No.6811
Thanks from Jan
Netherlands
Some photos of the modification.Note resistor bypassed so the ful 12 volts gets to the glowplug. Compare the original plugs to the mod ones. And the plugs wired up.Much more reliable plus gives off greater heat at the tips as you can see
I just bought a set from Forge services for my BTD6 drott
and then discovered I could get something closer to home For AD264 engine (is AD264 an Australian version or just a Typo)
http://www.ebay.com.au/itm/GPK4403-Glow-Plug-Kit-International-AWD6-AWD7-A554-564-Tractor-w-IH-AD264-Engine-/271290757911?pt=AU_HeavyMachineryParts&hash=item3f2a307317
also has pictorial instructions too, Did notice a thing at the bottom requiring a spacer for dozer engines Hope this is helpful.
