MF 244 Crawler
Topic author - Posts: 25
- Real name: Roger Norton
Re: MF 244 Crawler
Thanks Martyn but that link bears no resemblance to RE-connecting the wires I have.
For example, there is not a wire "going from the battery to the alternator" I havnt a clue what Ehow are on about
Re: MF 244 Crawler
the battery lead goes to the starter and a small cable comes off the motor on the same connection ( as normal ) so that would be your pos feed. on a negative earth machine, one of your cables off the alternator should go to your ameter as that indicates the charge rate,the charge then has to reach the battery in order to charge the battery.the only way that charge will get to the battery is via the small cable on the poss feed post on the starter.The same connection as you main poss feed battery lead ( therefore a route back to the battery ). connects on the pos post on the motor
Re: MF 244 Crawler
JimInOz wrote:Don,
I have a 2244 Wiring Diagram here,if needed.
Do you know what the differences are between the 2244 & the 244 ??
I thought that maybe the 244 were sold in Europe & the 2244 were sold elsewhere...maybe that's the only difference.
The two 2244 Loaders I have wrecked both have the 3-152 AD Perkins,& a Mechanical Shuttle.
I know of 2244s here in Australia,& in Canada & USA.Never seen a 244.
Jim
Hi Jim
Still struggling with re-wiring a new ammeter back into the MF 244.
I would like to get a look at your 2244 diagram if poss please
Regards
Roger
