v64paul wrote:Always go for the cheapest option first Julian. The pole wheel sensors were not usually that troublesome, look for contamination of the exciter rings. If the sensor sees a gap at speed the light will come on, the rear wheel bearings were usually the cause. They are a cartridge bearing containing the hub oil seal and non-adjustable. The seal would leak and the accumilation of gear oil and dirt would smother the exicter ring.
As for the rev counter, I'd have to check the manual, but yes that is as good a place to start as any. Check the alt drive belts are correctly adjusted as any slippage of the pulley will cause the output to drop. Scratch that, i've just read that it aint working at all, the dash is again a stand alone non-serviceable unit and has been known to give up.
If you pass on the year it was built and the chassis number i'll have a look at the relevant wiring diagram. We are probably looking at a site visit at some point, tea, no sugar please
![Laughing :lol:](./images/smilies/icon_lol.gif)
Thanks Paul. It's chassis # 54789 1987 EC12
I've done some work this morning, it has a vertical exhaust behind the cab, I noticed it was wobbling a bit and found the welds on the bracket to the chassis rail hadn't penetrated. My trusty stick welder and 3.2mm rods with a good blasting of amps has that sorted
Two oil filters on order from Fleet Factors for the engine and some new anti-freeze. I'm guessing that my semi-synthetic universal tractor oil is OK for the engine and ''blue'' antifreeze is OK?
Now to work out why it pulls to the right when braking - with cars it's always the front brakes that cause a pull, so I'm guessing that HGV is the same? Sounds like the left front brake needs investigation. I'll need to wait for the misses to come home from work because I can't push the pedal and watch that one at the same time
![Crying or Very Sad :cry:](./images/smilies/icon_cry.gif)
You are welcome to come on a site visit - tea will be never ending, I've one of those Burco 5 gallon water boilers
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
And you can see my other toys!
