Long and short of it is the vertical stack meant for a grey Fergie was almost entirely blocked with carbon
![Embarrassed :oops:](./images/smilies/icon_redface.gif)
![Doh :doh:](./images/smilies/ohnej.gif)
I didn't stretch to new rings and just put the piston I removed back in as was . One of the exhaust ports was bad with carbon and I lapped the valves in although they werent too bad .One of the injectors was carboned up and seemed to be almost completely blocked . I'm thinking I was running on as good as one cylinder since I got it . I cleaned up the outside of the injectors and started dismantling them - I just measured the adjuster clearance with a calliper and re set them to the same depth . I didn't get right into the injectors but by the end I was getting a proper spray pattern out of them and a nice plink .
New gasket set and did the tappets , couldn't help but notice massive play in the rocker arms . The bearings or bushes must be well gone .
Got it back together with the exhaust now just a straight through pipe and she started up eventually . It was a pig to start
What would be the downside if I slackened the injector adjusters half a turn each ?. Would that put too much fuel in ?.
Thanks Norm and others , the machine lives again
