I have been through the manuals, downloadable on this site but am struggling to find the right one (unless im being totally stupid, which is quite possible)
Its a sort of 3c2 but with a later dashboard, 2 fuse boxes, one on the right of steering wheel, one on left as per image.
I am finding wires in the original loom which don't relate to anything on the circuit diagram
Help or guidance would be vastly appreciated (again!)
Circuit Diagram???
Topic author - Posts: 59
- Real name: David
Circuit Diagram???
- Real name: David
Re: Circuit Diagram???
Thank - thank you -
What a difference looking at the correct diagram makes . My mind was looking for two banks of fuse boxes rather like the single bank on the first diagrams.
Thank you so much, both of you.
It does look like some jiggery pokery has been done under the dash, odd "extra bits" and they only had brown wire so following stuff is a bit of a bum job.
I do have more questions about the wiring but I am only going to ask if I really really get stuck as I don't want to be a pest. I should be capable of working it out but sometimes, like the fuses, I can't see the wood for the trees so will ask before the red mist sets in!!!!!
Still love my baby though!
David
David
- Real name: Mark Rive
- Has thanked: 33 times
- Been thanked: 26 times
Nephro wrote:Thank - thank you -
David
Hi David, glad to be of assistance. Ask away, I'll help as much as I can Mark
- Real name: David
OMG.....The electrics are causing me headaches....Have lifted the dash now instead of working upside down, looking up with the seat column in my back.
I suppose things are progressing, it just doesn't feel like it.
The tangle below is where I am at the moment. Each time I look at it I think......$&£*&%$£^ with a %£*&)(^ .
Vehicle electrics are NOT, definitely NOT my forte, I have learned Sooooooooo much about - hydraulics, diesel engines, repairing hammered fingers etc, I must just apply myself.
- Real name: David
OK.....Had a good morning. Decided to do a strip-out which will also let me sort out the cab properly.
Here is my resulting "mess"!
It has actually turned into a better job than I thought, have to get a new torque oil pressure and temp gauge but it seems most other things seem to work ok.I think the wiring "modifications" were done by someone from a spaghetti factory who only had red spaghetti......
Right....on with it. Thanks Mark and others for your encouragement.
ps.....it was a "bugger" getting the steering wheel off!
- Real name: David
Hmmm.
I have found one multi-pin socket going to the bulkhead (and matching plug on loom), one multi-pin socket going to the indicator stalk(and matching plug on loom), and a small multi-pin plug and socket to the torque/oil/pressure/temp gauge end, strangely I have 2 spare sockets in the dashboard. I am thinking that perhaps there should be more sockets on the bulkhead.
Does anybody know what I am missing?
Great success testing the dash panel itself, fuel, oil, battery indicator, switches and warning lights are all in working order, just got get them physically connected to things correctly now.
The ones marked in red are the stray ones (fairly sure but not 100% without going back to workshop)
David
Cold, wet and happy
David
Cold, wet and happy
- Real name: David
No. It's ok. Think I have sorted out what's not where. Doesn't help being colour blind either.
It seems I am missing a left sided electrics multi pin connector and a right side electrics multi pin connector.
When lady came out an found blue/green for me and labelled other colours I can't see, it made it easier.
Sent from my SE Arc S probably outside. Probably cold and wet.
