jcb powertrain drive
crew_cab
Real name: cath
Has thanked: 16 times
Post #1 by crew_cab » Sun Aug 09, 2026 2:44 pm
I HAVE A JCB 3C MK3 POWERTRAIN its been standing for around 2 years tried to move it yesterday and have no drive lifted the back end and just about moved the wheels brakes were stuck but managed to move them by lifting tyre with hi lift jack all move ok tried more oil but it blew out of dipstick
anyone have any idea before i scrap it
took ages to sort stuff out on it now this fed up any help please
agrimax
Real name: R
Has thanked: 14 times
Been thanked: 203 times
Re: jcb powertrain drive
Post #2 by agrimax » Sun Aug 09, 2026 9:43 pm
Is the dump valve pedal (clutch pedal if you like)free and not stuck down? Also need to get underneath and check the cable from the pedal is moving and that the dump valve itself isn't stuck in. Should be 20 thou of clearance when the pedal is up and the valve pin is out.
If there's no drive in either direction,the suction strainer in the square box on the bottom of the shuttle unit may also be blocked as well as the paper cartridge filter in the external bowl.
Just to add,also check that the actual shuttle lever is moving the rotary spool on the shuttle box too.
Has thanked: 971 times
Been thanked: 794 times
Post #3 by essexpete » Sun Aug 09, 2026 10:56 pm
Do all the things that Agrimax has suggested and if and leave it running for a while with the gear box in neutral and move the shuttle and leave in forward and the reverse for a while to warm up and then see if there is any improvement. TBH I don't think the shuttle box is massively expensive to repair if you have a need for a digger. Is the machine quite straight or generally knackered?
Billy26F5
Has thanked: 8 times
Been thanked: 72 times
Post #4 by Billy26F5 » Sun Aug 09, 2026 11:18 pm
I agree with that, there's a wee bit in the manual on the Powertrain setup but it's incomplete on the one here.
Sandy
crew_cab
Real name: cath
Post #5 by crew_cab » Tue Aug 11, 2026 1:30 am
essexpete wrote:Do all the things that Agrimax has suggested and if and leave it running for a while with the gear box in neutral and move the shuttle and leave in forward and the reverse for a while to warm up and then see if there is any improvement. TBH I don't think the shuttle box is massively expensive to repair if you have a need for a digger. Is the machine quite straight or generally knackered?
THE CAB IS ROUGH BUT REST OK TYRES BALD BUT ONLY USED IT FOR DIGGING IN ONE SPOT EXTENDING YARD NOW NO DRIVE SO DONT KNOW WHAT TO DO WITH IT ALREADY CHANGED FEW RAMS AND PIPES ON IT
SHOULD HAVE TRIED TO MOVE IT FIRST
Billy26F5
Post #6 by Billy26F5 » Tue Aug 11, 2026 2:42 pm
Cabs do go bad quickly, not a lot to get round that I'm afraid, I recommend you try to fix it yourself, then you'll feel better about it once done. If it's otherwise ok (tyres might be ok for now if your ground is not too bad, the front ones take a bit of finding) I would fix the drive issues, and if you decide not to you'll be better off selling than scrapping, the Powertrain models are very sought after by some folk and tend to be pricey. There were only some 6000 or so ever made.
Sandy
Post #7 by essexpete » Tue Aug 11, 2026 6:07 pm
I had not realised how few were made Sandy. They were the crossover between old and new. I always thought that with 4wd they would have been fantastic.
crew_cab
Real name: cath
Post #8 by crew_cab » Wed Aug 12, 2026 4:31 am
powertrain gearbox /torque convertor oils
is it best to drain the gear oils or just top up
Post #9 by essexpete » Wed Aug 12, 2026 8:31 am
The gear box is quite small and needs a 15w 40 like a Universal Tractor Transmission Oil. The shuttle requires different. It seems many use an ATF but the original spec was for a 10w transmission oil. The shuttle should be checked whilst the engine is at fast idle or immediately after stopping.
Billy26F5
Post #10 by Billy26F5 » Wed Aug 12, 2026 3:13 pm
I would renew the oils, you don't know what's in there. Torque convertor SAE 10W, Gearbox SAE 20W. Probably worth flushing through a bit to ensure no oil mixing occurs, don't run the engine to do that. Don't overfill the torque convertor.
Sandy
