Got back to my 1988 3cx 4X4 on start up blew ATF filter oil every ware (white) changed rusted out filter with very large stillsons, (I broke 2 filter removers) (Dumped ATF oil White )changed ATF fluid raised rear wheels on legs to find will go in reverse perfect but not forward, poss fault in indicator type selector switch, anyware else i need to look? Alternator frozen up solid also,belt just loosened for now, Can i swop anything to prove it will run in forward ? is there activators on top of gear box ? Radiator fluid was also low but a jubilee clip also rusted out and split on near side do they have an ATF fluid oil cooler If so ware do i look?
Thanks in advance any help greatfully excepted,
![Dizzy :dizzy:](./images/smilies/icon_shocked.gif)
