Hi all,
After ages and ages here's a double report on Mr. MacGregor.
Mr. MacGregor is a 1976 JCB 3CII, no. 113341, completed (I think) on 18 May of that year.
I would say he's pretty std., but if anyone else thinks something different then please let me know.
Now for serial numbers and casting codes:
Tractor number Leyland 384B/1/209615
Engine number Leyland 4/98NT/1792/36341
Gearbox number Leyland 10B 152590
Block Leyland 3K5
Frame Leyland 02B6
Gearbox Leyland 23A6 This one is a bit difficult to read
Axle LH Leyland 07A6
Axle RH Leyland 29H5
Starter Lucas M50G 26351E 19 75
Solenoid Lucas 18S 76854B 18 78 I don't think this is the original solenoid
Indicator switch Lucas 163SA 30492D 18 76
Injector pump CAV DPA 3249F850 Set A61/800/5/2440 Ser 9239 N S
Front wheels LH and RH Sankey IJ/75
Rear wheels LH and RH Sankey W14x28xA76
Steering pump Plessey type C 5 10024 No. 21M4163
Steering unit Plessey type HS 1257678 No. 4P512
Main hydraulic pump Hamworthy PA22I0G2B2A 011020A/76 0040/0351/6454
Loader valveblock Hamworthy VB1107DDI37VL I22035/B76 0040/0349 6334
Excavator valveblock Hamworthy VC1107DDDDDD134XL 012034 D/76 0040/0376/1204
Hydraclamp check valve Hamworthy CV04X2 013012 E/76 0040/0369/3366
Pipes
Loader valveblock feed 107/20200 4-76
Excavator valveblock feed 107/20500 C3 behind which is a strange I with an R superimposed, not sure what that means (pic bbelow).
Excavator valveblock return 107/20300 4 76
Loader frame lift 107/66300 4C behind which is a strange I with an R superimposed, not sure what that means.
Loader frame lower 107/66400 4-76
Shovel frame tip 656/00260 4-76
Shovel frame untip 107/67400 4-76
Shovel loader tip 108/23000 4C behind which is a strange I with an R superimposed, not sure what that means.
Shovel loader untip 108/23100 4C behind which is a strange I with an R superimposed, not sure what that means.
Hydraclamp return 102/95000 4-76
Hoses
Original
Pump 617/20400 G-4-76
Excavator valveblock return 617/21300 G-4-76
Loader valveblock return 617/20300 G 3 76
Loader valveblock lift 614/20600 G 2 76
Loader valveblock lower 614/20600 G-4-76
Shovel valveblock tip 614/20600 G-4-76
Shovel valveblock untip 614/20600 G 2 76
Shovel loader tip 614/00800 G 3 76
Shovel loader untip 614/00800 G 3 76
Loader LH lift 614/41400 G-4-76
Loader LH lower 614/41300 G 2 76
Loader RH lift 614/41400 G-4-76
Shovel LH tip 614/20400 G-1-76
Shovel LH untip 614/20400 G-1-76
Shovel RH tip 614/20400 G 3 76
Shovel RH untip 614/20400 G 3 76
Leg LH lower 611/20600 G 3 76
Leg LH lift 611/20600 G 3 76
Leg RH lower 611/20600 G 3 76
Leg RH lift 611/20600 G 3 76
Hydraclamp top 611/00600 2-76
Hydraclamp LH 611/21700 4-76
Boom kingpin lift 614/20900 G 3 76
Boom ram lift 614/20800 G-2-76
Dipper ram lower 614/41000 G 3 76
Power steering pump 617/00400 G 3 76
Power steering pump return 613/41700 4-76
Power steering feed 612/00200 G 3 76
Power steering return 612/00200 G 3 76
Power steering LH 612/20600 G 2 76
Power steering RH 612/20600 G 2 76
Power steering LH ram 612/21000 G 3 76
Power steering RH ram 612/21000 G 3 76
Front axle front 629/03200 G 3 76
Front axle rear 629/03000 G 3 76
Non original
Slew LH
Slew RH
Hydraclamp feed
Hydraclamp RH
Boom valveblock lift 614/20100 38/91
Boom valveblock lower
Dipper valveblock lift
Dipper valveblock lower
Bucket valveblock open
Bucket valveblock close
Dipper kingpin lift
Dipper kingpin lower
Bucket kingpin open
Bucket kingpin close 614/20900 43/87
Boom ram lower 614/20800 47/87
Bucket ram open
Unknown
Boom kingpin lower
Dipper ram lift
Bucket boom open
Bucket boom close
Bucket ram close
Boom grease
Lots of the non original hoses are completely wrong, the ones identified in the list are genuine JCB but a wee bit younger. Some hoses have no identification, so I don't know when they were made, but I do know that they're genuine. Looks a bit like there are lots of stock parts here but I might be wrong. I also read somewhere that JCB castings are dated too but I can't tell at the moment. I have found this though:
Slewing actor 13A6
Front LH hub SB 27-12 SAS76
There are other things on the other front hub and ram caps but I can't think that they're casting codes.
Here's the strange I with an R superimposed:
Our buckets: I think it's an 18" 4 1/2 cu ft bucket, a non JCB 12" 3 cu ft bucket, and a 60" back-filling blade that could be JCB but not the one I've seen advertised. The shovel is 80" wide and I think it's the 1 1/4 cu yd type, and it's had a handy shackle welded on.
As you can see the switches are a bit of a mess, but we'll hopefully sort that soon, and get the hazard unit too.
We also need to sort the stop and cold start retard cables. We also need to get the steering wheel and cold start plunger covers.
The seat is off a Land-Rover Defender, and I wish it hadn't been as it's very uncomfortable when swivelling.
Here you can see the mess with the hoses here. This is definitely worth sorting soon.
We also need to fix the clutch and brakes, the clutch has excessive free play and the pedal cross shaft bracket is bent to make it even worse. The brakes jam on, so they'll need a good check, but at least we're not with poor braking.
For more details about the skid unit see this: https://nuffieldtractor.com/viewtopic.php?t=5126
I don't know much about Mr. MacGregor's story,
We got him near Roy Bridge, and this is what he looked like then
Soon he moved to a nearby friend of my uncle (who lives nearby) and his workshop, again this is before anything was done (note the new soup can)
As you can see, the cab had plenty of the well known corrosion. Although supposedly fixed slightly after this our not having him under cover has put us back into a similar situation, but now I'm determined to get him under cover before fixing it so that the problems can be away for longer.
Unfortunately there's a load of pics from fixing him that are lost, I'm hopeful we'll recover them but it could take quite a long time as they've been lost for over 10 years!
This pic is at home, he sat for about four years as he had a leaking hose and we never seemed to find the time to replace it, but this had been done by this time. We'll need to get proper front tyres the sooner the better.
Also around the same time the rear bucket came off so we could fix the hole in the dipper, a still pending job.
Here clearing some blackthorn.
And just about to pull down a stuck tree, lucky to have had a cab for that!
Here we still have a problem as the o-rings seem to leak permanently, we fixed the slewing spool ages ago but the boom one is pouring out fluid. most other spools are too, but the plate above the o-ring seems unwilling to come out. The wiper seals are not good either.
He's very often not had a battery in or a very poor one, needing Billy to start him up.
This one is the first run since the hoses were changed, later in the year another one burst and that got replaced too; none of the hoses that came off were original.
And these are more recent
Quite a tight squeeze between Mr. MacGregor and Kenny for Billy to get in to. The barn is too, so we're used to that.
And running. The exhaust pipe was being painted at this point.
Hope you enjoy this.
Sandy
Mr. MacGregor
- Has thanked: 1889 times
- Been thanked: 1705 times
Topic author - Posts: 73
- Been thanked: 20 times
Re: Mr. MacGregor
I have to say I agree in many ways having seen the many JCBs in much worse state (condition or modification), but I'm keen to fix some of these things as it might then improve Mr. MacGregor's condition for longer. Until we get him under cover though we can't really expect anything to last particularly long, as although it's pretty dry here, damp nights are not uncommon and none of these machines like that much.
Sandy
Sandy
Re: Mr. MacGregor
Getting machines under cover if you are lucky enough to have that luxury is a 'must' it does make a big difference.
Re: Mr. MacGregor
We know all about that with the tractors, unfortunately the barn isn't big enough for all of our machines, but we're hoping to fix some other buildings to get them all under cover. Once that's done the cleaning starts and never finishes.
Sandy
Sandy
