Hi all
A question about tyre sizes .
One of my front tyres together with the inner tube is both knackered and now flat so I would like to get it replaced .
I need a bit of advice on tyre size before I order it .
The size on the tyre is 12.0 / 12.5 - 18
I have sourced a tyre at a reasonable price on the internet .
The size is 12.5 / 80 - 18 .
These are both 12 ply tyres but can anyone explain to me what the 80 denotes ?
Will this tyre fit ?
Machine is a JCB 3c11
Tyre sizes
Topic author - Posts: 201
- Real name: Chris
- Been thanked: 56 times
- Real name: Kári Össurarson
- Been thanked: 15 times
Re: Tyre sizes
My best guess is that these are two different methods of indicating aspect ratio, i.e. the ratio of the tyre height to width. If this is correct, your original tyre has an aspect ratio of 12/12.5 = 96%, and your proposed replacement has a height of 12.5*80% = 10 inches, meaning a diameter four inches less than the original. This might work for a 2wd machine, at least if you replace both tyres, but if it's 4wd you should be careful to keep to the original diameter.
Regards, Kári.
Regards, Kári.
- Real name: ian
- Has thanked: 126 times
Re: Tyre sizes
Not aware of the naming convention, so I wondered off to find some info.
This table is from a Firestone catalogue
The difference in the rolling radius is only 13mm, so I think it'd be an acceptable substitute.
![Image](http://www.classicmachinery.net/forum/images/userpix/67881_OVG7SX4T8VC31652761526.jpg)
- Real name: Chris
Re: Tyre sizes
Thank you all for your help . I will try and get a pic of the tread pattern today . I hadn't considered that the tyre might foul on the loader arms pete . Looking at the chart that gecko sent I think that there are some considerable differences in the tyre size I have chosen . It might make sense to renew both fronts at once although I really only want to get one side done . Cost against value of the machine as always is a consideration although it would only be one call out charge for the tyre fitter . I really don't fancy having a go at that ancient rubber myself and with limited equipment . Motorbike tyres are about my limit !
- Real name: Chris
Re: Tyre sizes
Well I have just had a good search of the internet and it seems like I will not be able to get the 12/12.5 - 18 tyre size . The nearest is going to be 12.5 /80 - 18 . That probably means I will definitely have to renew both fronts . I have downloaded some measurements from the spec sheets and will have a bit of a measure up today just to make sure there is sufficient clearance for turns and to see if they will fit the rims . It's a bit of a minefield .
- Real name: Chris
