You might be able to help me, again
![Smile :-)](./images/smilies/icon_e_smile.gif)
Im installing a newly refurbished CAV DPA injector pump back onto my build 5 powertrain.
Before this, the engine stop cable and the throttle cable were connected very poorly with incorrect springs/home made brackets etc.
Would any of you guys have a picture of the top of the injector pump so that i can see how these two cables are properly connected?
I know that there should be a spring between the end of the throttle cable and the and the throttle arm on the pump but i dont know what size, length, tension etc.
I also would like to see the way the cable and spring is fitted to the engine stop lever
Many thanks
