Hello,
I recently bought a JCB 3CX 4x4 sitemaster 1988.
Unfortunately Parking Brake it is not working and I have some problem
to find bracket location as show in diagram part n. 18.
Also i can't find FW and Reverse RELAY location as show in diagram part n. 46.
Does ANYONE has some pictures or can give some help?
Thanks in advance!
JCB 3CX 4x4 sitemaster 1988 Parking Brake & RELAY
- Has thanked: 1889 times
- Been thanked: 1705 times
Re: JCB 3CX 4x4 sitemaster 1988 Parking Brake & RELAY
Hi and welcome to the site I am sure somebody on here will be able to point you in the right direction.
Topic author - Posts: 6
- Real name: Costa
- Has thanked: 4 times
Thanks Jeremy,
Great forum you have here. Hope to receive some tips.
Already look in SPP and Service Manual and can't find more.
Maybe someone with a similiar machine can take some pictures and post.
That would be helpful.
Best Regards
Best Regards
- Real name: dylan jones
- Has thanked: 40 times
- Been thanked: 33 times
The forward and reverse relays will be on the talk converter i think.
I had all the handbrake on mine in bits last year to get it working. What do you want to know
- Real name: Costa
diggerjones wrote:The forward and reverse relays will be on the talk converter i think.
Hi Diggerjones,
the brake cable is loose on mine.
So I need to see where it tightens the clamp that holds it in the middle.
If you can make a video or take some pictures of the bottom of the machine it would be great.
If your saying the handbrake isn't working and you need it tightened, then on the prop with the brake disc there should be some sort of bolt or allen key
- Real name: Tim
- Has thanked: 191 times
On the handbrake front; item 18 is simply a clip that helps to tie the handbrake cable back to the chassis, all of the adjustment is on the the mechanical caliper at the transmission end, or beneath the rubber gaiter at the handbrake lever end inside the cab. I found that on mine the pads were so worn down that the previous owner had put a collection of over sized nuts and washers on the adjuster bolt where it acted on the caliper to try and make up for the complete lack of real adjustment left. A strip down of the caliper, followed by a good clean, a new set of pads fitted and then reassembly was all mine needed. It really is a very simple brake arrangement to take to pieces and get working again.
As for the forward/reverse shuttle relays, from memory they are located inside the steering column shroud down by the the transmission dump foot pedal, they send the power to the solenoids that are located inside the automatic gearbox section (which provides forward and reverse function) with the torque converter that sits between the engine and the 4 speed manual gearbox. I couldn't find the pictures last night when I started trying to find them, but I'm pretty sure they are shown somewhere in the project thread I created for my 1987 2wd 3CX
- Real name: Costa
Slooby wrote:On the handbrake front; item 18 is simply a clip that helps to tie the handbrake cable back to the chassis, all of the adjustment is on the the mechanical caliper at the transmission end, or beneath the rubber gaiter at the handbrake lever end inside the cab. I found that on mine the pads were so worn down that the previous owner had put a collection of over sized nuts and washers on the adjuster bolt where it acted on the caliper to try and make up for the complete lack of real adjustment left. A strip down of the caliper, followed by a good clean, a new set of pads fitted and then reassembly was all mine needed. It really is a very simple brake arrangement to take to pieces and get working again.
Hi Slooby,
I REALLY see that you are like me, someone who is not afraid to get their hands dirty.
Item 18 doesn't apears to be important but it is. Special when you don't have it, the parking brake will not work at all.
This happens to mine. The previous owner remove item 18 and i can't see where it is tight.
Can you take a picture to show where is tight in the chassis?
Thanks for your Post.
- Real name: Tim
qwaszx wrote:I REALLY see that you are like me, someone who is not afraid to get their hands dirty.
I think you'll probably find that nearly everyone on here is a fully paid-up member of the dirty fingernail* club!
If the weather isn't too bad tomorrow (it's being typically British winter at the moment - ie pervasive damp to tipping it down with rain) I'll climb underneath my digger and take a pic or two of the handbrake cable and adjuster mechanism. From memory, I think that clip 18 is missing on mine and there are just a few cable ties tying the handbrake cable up out of the way to anything that could be found
*I actually have to wear nitrile gloves when getting oily as I developed contact dermatitis and an allergy to petro-chemicals on my hands after an accident involving cellulose thinners when I was 19...
- Real name: Costa
Hi Slooby,
Thank you for your concern.
I know how the weather can be damp in the UK.
Over the past 3 weeks it has been rainy here in PT and it is expected at least another 2 weeks of rain and 70km/h of wind.
At least with photo i can see the route of the cable. On the way there I will find the hole for item 18.
The adjuster is easy. I started adjusting the cable until I found that it was loose.
By the way, I always start with orange nitrile gloves, and then i finish the day with my hands full of oil.
