Today I gave the old girl a treat and a pressure wash as it’s been so hot it’s dried off nice and quickly. I also intend to go around it replacing bits and pieces. Apart from one burst hose on the dipper ram which I replaced, the dipper ram has a pin hole on a weld so needs repairing. I have however today noticed one of the front loader hoses has split
![Embarrassed :oops:](./images/smilies/icon_redface.gif)
The front loader has some cracks around the hinge on one side so that needs welding properly. The other sides been done and holds fine.
I’ve also sorted the wiring a bit. I now have an ignition switch again, as before it had a push button on the dash with a quality assortment of bodges! I need a stop cable as it currently has what appears to be a coat hanger stopping it
I have managed to source a dashboard now which is complete so I can atlast try and make sense of the Reston of the wiring. I can also maybe find out how much fuel it has in at all times! I will need to sort out a set of glass though as otherwise the dashboard will be ruined come winter! I have given a little bit of paint to the cab and general digger whenever I find a spare 5 mins. Anything to help preserve it a bit longer! I would love to remove the cab next summer and weld it up
![Smile :)](./images/smilies/icon_e_smile.gif)
I do have a question though, does anyone know how long the oil pressure gauge pipe should be? Mine was cut when the half of the dash inc the speedo was ‘removed’. So I would like to order a pipe and have it ready for the dash when it arrives
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
