How to repack w welded piston jcb3cx-1400
Discuss loaders/backhoes here
gecko.cx
Real name: ian
Has thanked: 126 times
Been thanked: 117 times
Re: How to repack w welded piston jcb3cx-1400
Post #11 by gecko.cx » Wed Sep 06, 2023 5:13 am
ekmoor wrote:Does anyone know if the shaft is heat treated?
Mine is a later model, but I've just had mine straightened. The workshop the trued it up was pretty brutal and left a few witness scars on the rod surface. I was able to take out the worst by tapping with a hammer, so I'm quite confident the rod is not hardened.
Has thanked: 854 times
Been thanked: 697 times
Post #12 by essexpete » Wed Sep 06, 2023 5:56 pm
I used some liquid 2 pack resin in some pitting on my 814S bucket ram. It seems to have held.
gecko.cx
Real name: ian
Post #13 by gecko.cx » Wed Sep 06, 2023 7:08 pm
essexpete wrote:I used some liquid 2 pack resin in some pitting on my 814S bucket ram. It seems to have held.
It's impressive how well that stuff works.
The low spots weren't too bad, but the high spots were a bit sharp. I needed to "soften" the edges.
Post #14 by essexpete » Wed Sep 06, 2023 8:49 pm
I found a fine oil Stone good on slightly raised marks.
Gland seals can be quite forgiving. The old Weatherill shovel, that I still have, stood unused for several years. I am not sure if the rods were ever chromed. I am going back to late 70s when it was 25 years old. When I revived it the glands soon tore out. I had a pig of job splitting the rams (never could get the cylinder off). I used various grades of emery on an old orbital sander. Dad was dubious, but the rams went back with new seals and worked quite hard for years loading hay and straw.
ekmoor
Real name: Ed Moor
Has thanked: 1 time
Been thanked: 2 times
Post #15 by ekmoor » Wed Sep 13, 2023 11:31 pm
dropped it off to have the eye cut off and a 1/2 alignment dowel fitted to the eye and rod so the eye and rod are aligned during welding.
ekmoor
Real name: Ed Moor
Has thanked: 1 time
Post #16 by ekmoor » Mon Oct 02, 2023 9:48 pm
Cylinder eye was cut off with a lathe and rewelded after packaging was changed out. shop said that is how they are made with dowels to center the eye. Looks like a clean job....time for installation.
Savoy John
Real name: John
Post #17 by Savoy John » Mon Oct 16, 2023 2:36 pm
Good to see you got it done.
Return to “Loaders/Backhoes”
