Spacer Above the Bearing Cage Missing
gecko.cx
Real name: ian
Has thanked: 146 times
Been thanked: 150 times
Re: Spacer Above the Bearing Cage Missing
Post #11 by gecko.cx » Thu Jul 31, 2025 3:06 am
When I put that part number into JCB's parts list, it shows three parts (still #20 on the drawing)
Savoy John
Real name: John
Post #12 by Savoy John » Thu Jul 31, 2025 5:33 pm
gecko.cx,
That is the third exploded view that I've seen, all different. Would you look up the serial number and see what that view looks like?
Serial number is 3CXT4126/322593/7.
gecko.cx
Real name: ian
Post #13 by gecko.cx » Thu Jul 31, 2025 7:42 pm
Sure
I've had a 'first attempt' and it seems JCB are denying your machine exists
Following the link shows parts for machines built around 2021 (I'm guessing yours is older than that).
Savoy John
Real name: John
Post #14 by Savoy John » Fri Aug 01, 2025 6:13 pm
It is not a 3DX, its a 3CX. Alta came up with 3DX until he asked if it was four wheel drive (which it is) and apparently he found it, but, the exploded view of the spool assembly was different. How can this be so difficult!!!!!
I'll see if I can get a name and or number from the valve block, stay tuned!
I like a mystery but this is getting to be too much
gecko.cx
Real name: ian
Post #15 by gecko.cx » Sat Aug 02, 2025 9:01 pm
Savoy John wrote:It is not a 3DX, its a 3CX.
I'm not arguing with you, just showing what came up with that search.
I've tried any variations I can think of for your serial, but that the only thing that comes up.
Best guess is the NA models were numbered differently
Has thanked: 2057 times
Been thanked: 1836 times
Post #16 by Jeremy Rowland » Sun Aug 03, 2025 8:19 pm
This could very well be the case as it was an export machine, just makes it awkward when owners want to order spare parts.
gecko.cx
Real name: ian
Post #17 by gecko.cx » Mon Aug 04, 2025 5:48 am
Even the engine number is a bit odd.
"LH" is straight forward - it's a 4.236 with compensated injector pump.
"N" in last position says 1986 production
but there should be a letter in the middle showing which plant produced it.
gecko.cx
Real name: ian
Post #18 by gecko.cx » Mon Aug 04, 2025 6:52 am
Not strictly relevent as this relates to a Project 12 (about 10 years newer than yours), but this shows the weired / different serials used on north american (equivalent) models
Savoy John
Real name: John
Post #19 by Savoy John » Wed Aug 06, 2025 12:57 am
Making some progress with the numbers. I went to 777parts.com and found this (picture). Have to e-mail them to see what they come up with for an exploded view. Also, there is a tag on the valve body but I don't see a manufacturer. Did JCB make their own valving?
gecko.cx
Real name: ian
Post #20 by gecko.cx » Wed Aug 06, 2025 6:08 am
Savoy John wrote: Did JCB make their own valving?
AFAIK, valves blocks were all bought in.
I have no idea of dates, but yours might use Hamworthy valves.
Sometime during the Project 8 reign, Hamworthy valves were replaced by Husco valves.
