Classic pictures Updated 16/06/2024
Discuss heavy haulage here
Has thanked: 1295 times
Been thanked: 1111 times
Re: Classic pictures Update 28/12/2017
Post #2721 by FOWLER MAN » Fri Dec 29, 2017 11:52 pm
mechman wrote:Hi Fred
I looked at that but the chain looks as though it runs over the axle of the middle set of wheels which would turn them in the opposite rotation assuming its 6 wheel drive unless the top run of the chain drives the middle set some how. Can't get me head round it. :? :?
Norm
Hi Norman,
I didn't look closely enough at the pic. :oops: You are quite right. :thumbup:
The drive sprocket must be behind the top of the centre wheel. :think:
Would there have been room for a triple drive sprocket and another short chain, (which would be out of sight), to drive the centre wheel :?: :?: :?:
It is a puzzle :? :? :?
hair bear
Real name: Rob
Has thanked: 206 times
Been thanked: 284 times
Re: Classic pictures Update 29/12/2017
Post #2722 by hair bear » Sat Dec 30, 2017 12:30 am
Wow! Three years ago, almost to the day I asked about a particular type of loader which turned out to be a Bray HS4000. Lo and behould, second pic down I do believe is just such a machine, so somewhere one survives. Thanks for posting.
hair bear
Real name: Rob
Post #2723 by hair bear » Sat Dec 30, 2017 12:38 am
Norm
Hi Norman,
Would there be a small idler cog each side of the center wheel just behind the tyre so the chain runs up over then has a good wrap around under the cog then up over the other idler to keep the chain in contact? The top chain could then run over a third higher idler to keep it up out of the way of the drive?
mechman
Real name: norman orrick
Has thanked: 149 times
Been thanked: 136 times
Post #2724 by mechman » Sat Dec 30, 2017 2:21 am
Any one able to ID the machine?
Neversweat
Real name: Steve
Has thanked: 1255 times
Been thanked: 1856 times
Re: Classic pictures Update 30/12/2017
Post #2725 by Neversweat » Sat Dec 30, 2017 11:33 am
Steve
mechman
Post #2726 by mechman » Sat Dec 30, 2017 4:50 pm
mechman wrote:Any one able to ID the machine?
(looking like Meccano time). :dizzy: :?
Neversweat
Real name: Steve
Post #2727 by Neversweat » Sat Dec 30, 2017 5:05 pm
Steve
Osgood
Real name: Tony
Has thanked: 45 times
Been thanked: 48 times
Post #2728 by Osgood » Sat Dec 30, 2017 5:38 pm
hair bear wrote:[Would there be a small idler cog each side of the center wheel just behind the tyre so the chain runs up over then has a good wrap around under the cog then up over the other idler to keep the chain in contact? The top chain could then run over a third higher idler to keep it up out of the way of the drive?
Reckon you've nailed it :thumbup: With centre axle drive probably - idlers adjustable to take up chain slack.
hair bear
Real name: Rob
Post #2729 by hair bear » Sat Dec 30, 2017 8:56 pm
Thanks for the graphics. If you only knew how long I spent trying to describe that so it made sense!!!
Looking at the Berliet with the lowloader and 360, is this one of those situations where he drives along the trailer, takes most of the weight off the drive axle, and the whole lot goes skating down the hill?
Neversweat
Real name: Steve
Re: Classic pictures Update 31/12/2017
Post #2730 by Neversweat » Sun Dec 31, 2017 11:40 am
Steve
Return to “Heavy Haulage”
