Cat D5b
Topic author - Posts: 23
- Real name: David
- Been thanked: 18 times
Cat D5b
I thought I'd try a spot of dam building with the Cat, expected it to be quite slow but on a short distance haul the fastest way to shift the muck.
- Real name: Richard
- Has thanked: 28 times
- Been thanked: 46 times
- Real name: tony coates
- Been thanked: 63 times
Re: Cat D5b
RJW, that Scraper turns out to be "Farm Grown" out of some bits from the Farm Yard Scrap Heap painted a rather nice shade of Yellow made a few wet weekends ago??? it looks a neat little outfit, well done David.
tctractors
tctractors
Re: Cat D5b
RichardJW~ wrote:TC,
it does indeed look good!.....credit to you, David
It does indeed David
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
![Question :?:](./images/smilies/icon_question.gif)
- Real name: David
Re: Cat D5b
More pics in a day or two
The scraper was built to go behind a Case Magnum and it does go well and is very fast using the powershift traveling, but then it rained !. So we hitched it to the Cat, in third gear using the full 165hp what it looses in speed it gains in handling on the ramps and embankments.
The bowl is 3 meters wide x 2m x 1.5m so I guess that is about 8 yards or so, digging, transporting, leveling and compacting in layers all in one operation is pretty efficient with a short haul distance. Our PC130 was just used to tidy the corners and final grading of the slopes.
The only downside was the linkage hydraulic pump has not got enough flow to give a good response on the blade or ejector plate so an upgrade there will improve it.
Dave
Dave
- Real name: David
Re: Cat D5b
Closer pics as promised
