Tractor Ford 5000 brake system
I have Ford 5000 hydromatic tractor, which I suddenly lost brake on it . Any suggestion of haw to remedy the problem. Many thanks
Re: Tractor Ford 5000 brake system
Have you sorted? What is a Hydromatic? No expert but that series usually have mechanically actuated oil immersed discs. First point of call would, IMHO, be to check thro' the linkage on that side.
- Real name: Paul Griffiths
- Has thanked: 384 times
- Been thanked: 256 times
Pete I would be guessing hydromatic is the Ford Selectospeed
If you have lost brakes is it only one side as Pete Suggests ?? some more information may help
- Real name: Richard
- Has thanked: 28 times
- Been thanked: 46 times
Brakes on Ford 5000s are mechanical rod operating expanding discs which are immersed in either side of the rear axle oil.
have you checked the adjustment - there are two jam nuts down on the clevises under the footplates, you'll need 2 x 11/16" open enders and the correct free-play used to be about 3" of travel
