Just got a Norscot 992G and want to replace the plastic hand rails with metal ones.
What thinkness wire is a good match for 1:50 scale - somewhere around 1mm?
I was also thinking about using stainless wire instead of brass thinking that it may be a little stronger, however, is it possible to solder stainless with a gas soldering iron (done it before with brass but never tried stainless with normal solder)?
Thank you
Dave
Norscot 992G
- Real name: Martin Williams
- Has thanked: 9 times
- Been thanked: 43 times
Re: Norscot 992G
Hi Dah,
For handrails on 1:50 models I use 1/32 (0.81mm) brass rod. Its thin enough to bend but once soldered is pretty strong.
For hydraulic hoses I buy a pair of 99p MP3 player headphones and cut them up.
I'm trying to find some photos for you. This is a WA800 project i have on the go. The replaced handrails on the access steps are brass and the hyd lines are headphone wire.
URL of the original image: http://i144.photobucket.com/albums/r177/mammut_photos/WA800%20project/2014_04230005.jpg
Here you can see the difference between the brass for the mirror arms and the plastic handrails.
URL of the original image: http://i144.photobucket.com/albums/r177/mammut_photos/WA800%20project/2014_04300004.jpg
Topic author - Posts: 395
- Real name: Dave
- Has thanked: 18 times
- Been thanked: 68 times
Re: Norscot 992G
Thanks Martin - looks great!
Realised after I posted the question that I wouldn't be able to solder stainless so I'm back on the brass!
Ive looked on ebay and can see lots of 1mm brass wire - I guess its the same as 1mm rod but just needs straightening?
Great top with the headphones btw!!!
- Real name: Dave
Re: Norscot 992G
Hi Martin,
I will definately post some pictures - uless it goes horribly wrong!
Thinking about is, I'm guessing typical handrails are around 40mm in real life so guess 0.8mm is bang on scale for 1:50?
Sorry - one more question (getting a bit excited / carried away!). How do you go about matching the paint for your WA800? Looks perfect patch.
Thanks,
David
Thanks,
David
Re: Norscot 992G
I've not really matched it yet, I've put all the bits on but still yet to paint it.
I'm colour blind so what I think looks right will probably be a million miles away!
Someone somewhere will have the paint code.
