Thwaites 7000 series 3 ton Dumper
Topic author - Posts: 6
- Real name: Mike Smith
Looking for a repair to my gearbox. A local engineer has tried to locate parts but no one he has contacted seems to recognize my machine. The markings on the front axle are as follows...3801013TX3A014 and on the gearbox 203-4438. The gearbox has three forward gears and one reverse and is linked to a Lister/Petter 3 cylinder diesel engine. Would appreciate help in locating necessary parts.
- Real name: Gerard
- Has thanked: 17 times
- Been thanked: 60 times
Re: Thwaites 7000 series 3 ton Dumper
http://source.theengineer.co.uk/newage-transmissions/1566.supplier
if it is try that link of google Newage coventry. http://www.newage-prm.co.uk/
have a look there hope thats some help.
Hi Gerard, have been in contact with Newage but they can't help...my Dumper gearbox was ceased some 15 years ago and no spares are now available...many thanks for your suggestion... Mike
- Real name: Gerard
A dog used to be a mans best friend , now google is, try
http://www.davidcornwallis.com/index.php
just a site I found on google, they might be able to help you out.
Gerard
Gerard
Hi Gerard, once again many thanks....that was one site I had tried once before without much luck..the gearbox I have is, I believe a 95M and it seems that internal replacement parts are unobtainable. Looks like a complete replacement gearbox will be required!
- Real name: Andy
- Been thanked: 11 times
Plant and Engineering in Beare, Exeter are good at old Gearbox and Axle spares. Might be worth a try.
http://www.plantengineeringservices.co.uk/
Regards
Andy
Regards
Andy
Hi Andy,
Thanks for your response...have tried them..they identified the gearbox I have but couldn't get parts to repair...I think a replacement gearbox is my only option...
Once again, thanks for trying to help
Mike
Mike
- Real name: Dave
- Has thanked: 57 times
- Been thanked: 5 times
mikelsmith wrote:Hi Andy,
Mike
Depending on what gears/parts are needed you could try asking local engineering firms - there are a number about all over the country that make gears. some firms advertise in Old Glory for doing parts like gears for the traction engines (full size and minatures). (Got to be some business out there looking for some work to keep the machine tools going)
There is/was a firm at Chesterfield that does allsorts of gears and makes one offs/small batches. I had a catalogue from them some were but cannot remember were it is at the moment (filled in the loft) or what they are called. Also used to be a yard full of dumpers down there ex hire co mainly that used to be patched/painted up in batches for export i think, but they packed up a few years ago and the yard was cleared out
If its just worn teeth it could be built up & machined down if straight cut gears, but a 'new' used box may be cheaper and quicker if you can find one.
Dave
