Newage 40 gearbox
Discuss dumpers here
Mattj 345
Real name: Matt Jones
Been thanked: 4 times
Newage 40 gearbox
Post #1 by Mattj 345 » Wed Feb 23, 2022 12:06 pm
Is it possible to swap over the drum clutch assembly onto a gearbox with the bell housing clutch, I've got a spare gearbox to go onto the aveling barford sd 06 I'm working on, the one that's in it is worn out.
Mattj 345
Re: Newage 40 gearbox
Post #2 by Mattj 345 » Wed Feb 23, 2022 12:10 pm
Mattj 345
Post #3 by Mattj 345 » Wed Feb 23, 2022 1:28 pm
Here's a couple of pics of the replacement box
Whitlock 505
Real name: Ian Perrott
Has thanked: 92 times
Been thanked: 88 times
Post #4 by Whitlock 505 » Thu Feb 24, 2022 11:09 pm
Hi Matt
I've just restored a Stothert & Pitt/ Aveling Barford SD06 and that's a different set up to the one i have. The gearbox I have in mine is tiny and to give you some idea of the size it has a bell housing on it with a 6" clutch of a hillman imp that is connected direct to the Lister LT1 engine
Whitlock 505
Post #5 by Whitlock 505 » Thu Feb 24, 2022 11:16 pm
I've also done a newage 40 gearbox on a Benford 2000 dumper I have and the bell housing should part from the front of the newage 40 if you wanted to swap over gearboxes if I'm correct in what your thinking? I'll post some pics
Whitlock 505
Post #6 by Whitlock 505 » Thu Feb 24, 2022 11:27 pm
Whitlock 505
Post #7 by Whitlock 505 » Thu Feb 24, 2022 11:36 pm
Whitlock 505
Post #8 by Whitlock 505 » Thu Feb 24, 2022 11:41 pm
Just seen your reply on my post on my SD06 :doh:
Mattj 345
Post #9 by Mattj 345 » Fri Feb 25, 2022 11:43 am
That was the plan with it I'll hopefully manage to drop the gearbox that's on it out the clutch doesn't disengage as I found
out put my foot on the clutch and it did go into gear and shot forward off the block, I can't remember off hand when grandad converted it, after unsezing the engine it fired up first time .
Return to “Dumpers”
