I'm new here and to Dumpers, I'm looking for some help with Nimbus 40M gearbox, gears very crunchy and I don't think clutch is fully working, any advice for a novice, pics available
![Image](http://www.classicmachinery.net/forum/images/userpix/69496_Q6QVL9V02IVB1605028123.jpg)
Jeremy Rowland wrote:Hi and welcome to the siteI am guessing that the clutch is either mechanically activated by a rod? If so there should be some adjustment on it? If not then it must be hydraulically activated? If so there may be no adjustment possible which may mean replacing the clutch unless you have a master or slave cylinder fault, is the pedal spongy when you depress the clutch? There are plenty of dumper owners on here who can offer better advice than me.
freddyuk wrote:I have the same dumper and the clutch has started making a noise when pedal depressed. Would that be a thrust bearing? Quiet when out but noisy when in. Is it easy to replace?
