Hi , I'm new here.
I Just bought this machine off Ebay to use around my small farm. It has a 3 cylinder Lister Petter air cooled engine which I understand is a TS3. Does start fine and seems to run ok but machine is in a right old state. Main problem is there is oil pouring from the steering ram, the end of the ram cylinder will not tighten up so it looks like the threads are stripped and therefore because of this and the pitted rod it needs a new ram, any ideas where to get one affordably?
There is no engine cover, I will probably end up making one but I'd thought I'd mention it in case anyone had a spares machine with one on.
Other main problem (apart from very worn main pivot) is the battery isn't charging. There isn't an external alternator, just wires from stator. One red pair and one black pair. There are ohms readings on there of 13 ohms per pair, and when running I'm getting 17VAC on the black pair and about 45VAC on the red pair. The rectifier/regulator unit has a broken off terminal so hopefully if I can find one of these units it will solve the problem, anyone know where to get or what can be used instead? I wondered if a motorcycle one might work.
Lastly, anyone know how to tell what year the machine might be? IF I had to guess I would say early 1990s. Thankyou
