Still confused which model I have......
Discuss dumpers here
freddyuk
Been thanked: 8 times
Post #1 by freddyuk » Thu Apr 30, 2026 4:15 pm
I am about to rebuild my small dumper which I have used after fitting new brakes and filters but since then it has sat unused and suffered a bit from the rust. I never really identified what it was so I am posting pics again to see if anyone has the same?
Getting parts is difficult although I did get brake parts a few years ago (lockheed drums with cable/rod actuators) which may be off a Triumph Herald??
These have become a bit seized as I live on the coast. The axle is a Salisbury but I cannot easily get the filler off as there is an elbow fitting instsalled which stops a socket fitting it so aqn open ended spanner is all I can use but it has never been off in recent history so unlikely that will work.
The number plate is a UK "H" so 1970 year. It now resides in West Cork, Ireland. Looking at the steering geometry it does not match any other small dumper I can find??
Apart from David Cornwallis are there any other suppliers of parts for these historic machines?
Image See other images in my gallery
Has thanked: 949 times
Been thanked: 786 times
Re: Still confused which model I have......
Post #2 by essexpete » Fri May 01, 2026 2:16 pm
Have you more photos?
freddyuk
Post #3 by freddyuk » Sat May 02, 2026 2:03 pm
They are in my gallery but how do I post these? I cannot see an option to do this or give you access to it???
Has thanked: 2070 times
Been thanked: 1845 times
Post #4 by Jeremy Rowland » Sat May 02, 2026 8:04 pm
freddyuk wrote:They are in my gallery but how do I post these? I cannot see an option to do this or give you access to it???
When you post, look for the tab 'upload pic' click on that, then locate each photo and post when you have uploaded them all, hope that helps.
freddyuk
Post #5 by freddyuk » Sun May 03, 2026 8:59 pm
Post #6 by essexpete » Mon May 04, 2026 6:35 pm
It is very similar to the Thwaites Nimbus of that era, particularly with the left-hand drive. It looks to be a 15 cwt size.
freddyuk
Post #7 by freddyuk » Tue May 05, 2026 9:17 pm
Thanks. So are there any suppliers of parts left of are they all gone now? Engines are well served but the actual chassis parts are getting imposiible to find. The brakes are Lockheed all NLA....
freddyuk
Post #8 by freddyuk » Thu May 07, 2026 10:44 am
Looking at some Youtubes it is definitely a Nimbus - thank you. However mine has the engine facing in reverse direction to others I have seen. I have a direct drive via a cluth to the axle.
The steering is the same - lots of ball joints and king pins that need replacing.
freddyuk
Post #10 by freddyuk » Fri May 08, 2026 8:57 am
Thank you for this info it will go into my file and I will get the spanners out on the gearbox soon.
Return to “Dumpers”
