Thwaites 2 or 2.5 ton petter ph2 dumper
Discuss dumpers here
mechman
Real name: norman orrick
Has thanked: 203 times
Been thanked: 162 times
Re: Thwaites 2 or 2.5 ton petter ph2 dumper
Post #41 by mechman » Mon May 19, 2025 10:21 am
verdone wrote:Question, when you do the spill timing. Do you put the fuel rack in max fuel position with the overload stop?
Or do you put the fuel rack in normal running mode?
Verdone
The mark on the fuel rack spindle has to be a certain distance from the side of the pump (I think it's 13/16") not sure now. There are two measurements
given.
Norm.
verdone
Has thanked: 7 times
Been thanked: 14 times
Flag: France
Post #42 by verdone » Wed May 28, 2025 12:58 pm
I finally got it running after fiddling and thinking a pump was bad but it turned out a injector that i set up went bad again?? So i cleaned it out and reset pressure and now it runs on both cylinders. The only thing that worries me it doesnt make that creak sound when it opens up?
I think i got the spilltiming and measurements right, i only had a short drive cause the flexible brake pipe hose started leaking :dizzy:
I will post some pictures soon!
Has thanked: 2094 times
Been thanked: 1874 times
Post #43 by Jeremy Rowland » Wed May 28, 2025 8:12 pm
verdone wrote:I finally got it running after fiddling and thinking a pump was bad but it turned out a injector that i set up went bad again?? So i cleaned it out and reset pressure and now it runs on both cylinders. The only thing that worries me it doesnt make that creak sound when it opens up?
Not all injectors make the creak sound, so I wouldn't worry too much about that. :thumbup:
verdone
Flag: France
Post #44 by verdone » Fri May 30, 2025 7:49 pm
I refitted everything because it was running fine and then i start it again and it seems that one injector is faulty again, it is like it wont hold the opening pressure is set it at?
I ordered a "new" one and hopefully this sorts it out else i am at a loss since i did the spilltiming and setting the fuel rack to the book i think.
Will keep you guys updated!
For anyone interested we posted another video of the dumper.
Part 2: https://www.youtube.com/watch?v=Z712mfQ-L-g
Part 3: https://www.youtube.com/watch?v=OL7U9KujEn0
Verdone
verdone
Flag: France
Post #45 by verdone » Sun Jul 06, 2025 8:41 am
Little update, i have rebuild both the injectors and it was a world of difference but then the starter broke :evil: by the end of this sage i will have replaced everything :dizzy:
We have another episode on the dumper whoever is interested.
https://www.youtube.com/watch?v=3PhqbSDtmhU&t=40s
Return to “Dumpers”
