Thwaites 2 or 2.5 ton petter ph2 dumper
davidbrown80
- Real name: Roland
- Has thanked: 7 times
- Been thanked: 6 times
verdone
Topic author - Posts: 37
- Been thanked: 14 times
Re: Thwaites 2 or 2.5 ton petter ph2 dumper
davidbrown80 wrote:i think its a Thwaites Alldrive
It is indeed a thwaites alldrive 4000 but what year it is from no idea. It is still going strong and has moved 1300m3 of earth already but the engine is getting tired so it will need some tlc real soon.
verdone
The time has come to open it up, pistons and cylinders worn out. Replacing them + new bearings and cleaning out everything and putting in new seals wherever i can.
Will keep you updated as i go along. I have a YouTube channel where we post videos and the dumper will come in one of the future videos called Domaine Sauvage for anyone interested.
verdone
I have all the parts now, i ordered them from stationaryparts in the UK and within 2 days i had them neatly packed in France.
The valves have been regrinded and tomorrow i will start putting in the new pistons and cylinder, i will try to remember to take a picture here and there as i progress.
verdone
New cylinder housing on and checking the bump clearance.
- Has thanked: 2045 times
- Been thanked: 1829 times
verdone wrote:Stupid question: How do i check compression since there are no glow plugs, is there a tool to check through the injector hole?
Yes, that's how it is done, but if you've renewed all then compression should not be an issue so long as your valve seats are okay, a simple turn of the engine by hand will also let you know you have good compression, well give you a fair idea.
mechman
- Real name: norman orrick
- Has thanked: 191 times
- Been thanked: 153 times
verdone.
I changed the pumps on a PH2 and it can be confusing setting the timing up with the marks on the fly wheel. Mine had 10 timing marks on the fly wheel ( 5 each at 180 degrees to each other ) I'm sure the engine can run both ways hence the two lots of timing marks. The before TDC marks 2 either side of TDC are for ( nearly sure) single cylinder Ph1 and twin cylinder Ph2. There's only a couple of degrees between them not sure how critical it is. Got mine done after a bit of head scratching.
Norm.
Norm.
verdone
Thx Norm, once all my engine bits are cleaned up and bolted back on i will have a look at getting the diesel pumps done. Hopefully i get it right like you.
