We have a Thwaites Orion Dumper, which has been great, however I was using it yesterday and after 3 or 4 hours it is stuck in gear? any solutions please?
Many Thanks,
Alwyn
Thwaites Orion Dumper Stuck in Gear
- Has thanked: 931 times
- Been thanked: 768 times
Re: Thwaites Orion Dumper Stuck in Gear
Probably easiest to take the top off the gear box complete with the lever. At a guess the end of the gear lever has left a selector behind, as it were. The old (probably Newage) gear boxes are fairly simple. You can buy a new plate and spring and even a lever if the ball is worn ( I have welded up one with partial success). If the selectors are knackered that might be a bit more involved. You also see what sort of state the inside is, these old boxes are prone to water ingress down the gear lever.
Tillywolves
- Real name: Richard
- Has thanked: 21 times
- Been thanked: 33 times
If its the 40M2S gearbox, this is the manual.
https://www.winget.co.uk/wp-content/upl ... EARBOX.pdf
Parts
https://www.lsengineers.co.uk/site-dump ... arbox.html
Parts
