Thwaites 2 or 2.5 ton petter ph2 dumper
Discuss dumpers here
verdone
Has thanked: 2 times
Been thanked: 3 times
Flag: France
Re: Thwaites 2 or 2.5 ton petter ph2 dumper
Post #11 by verdone » Tue Jul 30, 2024 4:54 pm
Brakes are done, luckely the bad brake fluid only took out the cylinder and didnt get into the diff with the brakes, we disconnected the brake line towards the front diff and cleaned it out and the first part was luckely mineral oil and not synthetic :claphands:
The little propshaft between the gearbox and transfer box is fixed as well so the dumper is looking a lot better already!
verdone
Flag: France
Post #12 by verdone » Thu Aug 01, 2024 11:09 pm
All fluids and filters done, now i will see to order the correct seals for the leaks i am having and i think the bad idling is because of the fuel stopper hinge on the fuel rack that is worn.
Took it out for a drive today and it does have plenty of power, pulled my trailer behind it which was almost 3 ton so not bad at all. It does smoke a bit so i am hoping i can fix that with some diesel additives to clean out the injectors etc.
Will keep you updated!
Has thanked: 874 times
Been thanked: 715 times
Post #13 by essexpete » Fri Aug 02, 2024 8:29 am
I think a bit of smoke is unavoidable with that breed of engine.
verdone
Flag: France
Post #14 by verdone » Sat Aug 03, 2024 10:07 pm
essexpete wrote:I think a bit of smoke is unavoidable with that breed of engine.
Once it is up to its full revs it stop smoking so thats good, it is in between it can be a bit smokey. But i think that is all to do with the fuel rack needing a tune up, that has to wait though i need it next week for two weeks.
verdone
Flag: France
Post #15 by verdone » Mon Aug 05, 2024 10:33 pm
The more i drive it the better the engine is starting to run, it idles better now with less hunting :claphands: :D
Tomorrow it will be its first workday so fingers crossed!
verdone
Flag: France
Post #16 by verdone » Sun Aug 11, 2024 9:38 pm
I have been working with it for a few days, no major problems :claphands:
The only thing is when braking under load they do make a grinding noise, so i'm guessing they will need replacing...
Post #17 by essexpete » Sun Aug 11, 2024 11:02 pm
I can't remember, have you changed the oil in axle?
verdone
Flag: France
Post #18 by verdone » Sun Aug 11, 2024 11:10 pm
essexpete wrote:I can't remember, have you changed the oil in axle?
Yes with oil that is specific for oil immersed brakes. When braking without any load it is fine but when the bucket is full and i brake it makes a good grinding noise.
Post #19 by essexpete » Mon Aug 12, 2024 8:33 am
I have had brake chatter on dumper axle, Manitou Spicer axle and the old JCB powertrain brakes. I used a Q8 UTTO that was fine in Ford and a Case tractors that made the Manitou axles sound like it was disintegrating. (It also upset the limited slip diff). I used a gear oil designed for limited slip diffs which partly helped. The old JCB we used JCB's own brand, again it helped but was still noisy. Our old Sanderson telehandler has outboard hub brakes, they have always been noisy (and poor).
I don't know why this should be as the tractors have always been OK.
verdone
Flag: France
Post #20 by verdone » Thu Sep 12, 2024 10:17 pm
It is still running strong, i got parts on the way to stop numerous leaking issues though :claphands: :D
Return to “Dumpers”
