Parts for Petter engine - available??
Discuss dumpers here
freddyuk
Been thanked: 8 times
Post #1 by freddyuk » Mon Apr 29, 2024 10:48 am
I have dug my old Thwaites 1 ton dumper out of the mud and given her a wash down. Starts first time as ever. She has a Petter single cylinder engine. The flywheel was fouling the tinware as this had started to come apart so I needed to remove it and maybe build a cage around the flywheel. I doscovered it is impossible to remove the flywheel guard without lifting the engine or removing the rear axle!! In the end I cut some of the tin to get it off. After a jet wash I have an oil leak from the oil pipe which goes from the cylinder head down to just behind the oil filter so I need to replace this pipe which has banjos on each end. Will I be able to purchase this from anywhere or is there another solution for this. Thanks guys
Has thanked: 1968 times
Been thanked: 1768 times
Re: Parts for Petter engine - available??
Post #2 by Jeremy Rowland » Mon Apr 29, 2024 8:36 pm
Although I don't know what this pipe looks like, I would imagine that you could get a new end soldered on if it was leaking on the end, if the pipe has holed I can't see why you could not but some and make one yourself, or again a good soldered repair.
mechman
Real name: norman orrick
Has thanked: 167 times
Been thanked: 144 times
Post #3 by mechman » Mon Apr 29, 2024 11:58 pm
freddyuk. L.E.S. engineering sell stuff for Petters, don't Know about the rocker oil feed pipe ,they might point you in right direction.
Norm
Tillywolves
Real name: Richard
Has thanked: 21 times
Been thanked: 33 times
Post #4 by Tillywolves » Mon May 06, 2024 8:02 pm
AndyM
Real name: Andrew Martin
Post #5 by AndyM » Tue Aug 13, 2024 4:57 pm
Mead Plant are pretty good as well for old Petter spares
https://www.meadplant.com/
Return to “Dumpers”
