Here you go
1985 benford TT3000
Re: 1985 benford TT3000
Well, the steering valve seems ok with no leaks, unfortunately the oil feed pipe repair was unsuccessful, so a new one will be ordered.
Another little leak seems to have appeared, 2 of the 3 injector pipes are leaking from the top connection, I removed and cleaned them and they’re still leaking.
Anyone ever been successful at stopping these leaking, before I bite the bullet and buy a couple of new ones.
On closer inspection it appears the leak is running down the outside of the long connecting nut at the top, so I would say whatever it screws into is the culprit.
How much has to be removed before I can get to the connection
- Real name: John
- Has thanked: 303 times
- Been thanked: 138 times
Looking at your pic that lever has to move upwards in the direction of the arrow as seen on the engine block. There is the remains of what looks like a ball joint on the lever which I think would have been a part ofhe inner cable for stopping
