Can you tell what it is it???
A snapped bucket tilt cylinder on a 992G, not really sure why it broke but it did...
Note how the rod is hollow.....
SB
Expensive break.....
Topic author - Posts: 1247
- Real name: Stu Bickley
- Has thanked: 70 times
- Been thanked: 116 times
- Real name: Jim M
- Has thanked: 58 times
- Been thanked: 86 times
Re: Expensive break.....
The rod end has snapped off which carries the seals hasn't it? and is still in cylinder? I suppose taking the end cap off will show if the cylinder has been damaged or scored by the rod. I would imagine this is going to be expensive especially being on this size machine.
- Real name: Ross
- Been thanked: 27 times
Cracking pics Stu (no pun intended )
Looks like they are loading Hi-cube bodys and the Cylinders are going to full stroke every load ..
Same happened up at Teck .. The would ride the loader arms up the bodys to get the extra hight and then full tilt dump ..
In the end they had to Replace the 992 with a 994F ...
Bit hard to tell, but it looks like a fairly clean break, no sign of fatigue.
- Real name: John Gaunt
It looks like there is a crack propagating down the shaft. If the break was right at the end where, presumably the 'piston' is welded onto the shaft ? maybe there was a weakness in the weld which finally gave way under extreme load conditions.
It's wired how it cracked, obviously it was part way through bending and being hardened chrome moly I would think are they, it wouldn't just bend but snapped and stress cracked at the same time. It's a bit of a croked break to, things like that normally snap pretty straight.
- Real name: aongheas macaskill
Ross wrote:Cracking pics Stu (no pun intended )
If the rams are going to full stroke should there not be bucket stops to eliminate the rams bottoming out?
- Real name: Ross
Aye well it was always the Hoist cylinders that broke ..
I would assume it has bucket stops ?? Never worked on these Mono-Boom Junk ..
Return to “Accidents and Bogged in machines”
