The variety of Poclain designs (and obviously the cross-language translation issues with engineering terms) is somewhat confusing. If you see a Poclain in the flesh, unless you are lucky enough to find and be able to read the data plate, its a 75, 90, 160 or whatever. Most of the Poclain's I've seen over the last few years have been scrap handlers, standard machines more or less with long booms fitted with a 4 or 6 tine grapple. I can only recall a single example with a high-view cab.
Do the designations for Poclain machines relate to specialist versions of these? Is there a rough translation guide to be found? On plant sales sites, CK, CKB and CL seem to be the most common suffixes used but as to what they actually mean?
Best regards
Gavin
