JCB 3C II 1973 replace Fan Belt
Discuss excavators here
Dave-OLW
Real name: David
Been thanked: 3 times
Post #1 by Dave-OLW » Thu Aug 06, 2026 9:36 am
JCB 3C II 1973 Engine serial No. 6797 Leyland 4/98NT.
How to replace Fan belt, remove hydraulic pump/just unbolt from pulley?
Thanks David
Has thanked: 971 times
Been thanked: 794 times
Re: JCB 3C II 1973 replace Fan Belt
Post #2 by essexpete » Thu Aug 06, 2026 12:47 pm
It is many years since I changed a fan belt on a 3C, but I think if you can remove the bolts holding the shaft to the crank pully, you can get enough space by sliding the shaft on the splines. It is a bit of a pig if I remember correctly. Some tie back a spare belt at the same time. I found that a waste of time as the couple of times I did that, the belt was either rubbed or oil contaminated.
Dave-OLW
Real name: David
Post #3 by Dave-OLW » Thu Aug 06, 2026 2:44 pm
I'll try that
David
Billy26F5
Has thanked: 8 times
Been thanked: 72 times
Post #4 by Billy26F5 » Sat Aug 08, 2026 11:25 pm
Just unbolt the shaft from the pulley, don't put a second belt as Pete says for those reasons. Bolts are awkward.
Sandy
Return to “Excavators”
