Hymac 580BT 1969
Discuss excavators here
Has thanked: 2087 times
Been thanked: 1869 times
Re: Hymac 580BT 1969
Post #191 by Jeremy Rowland » Mon Nov 20, 2023 8:33 pm
essexpete wrote:Where, out of interest, did you source the new rubbery gaters?
Pete they are not quite the right fit unfortunately but they came off EBay; I may order some mre but a slightly smaller diameter for hopefully a better fit?
Post #192 by Jeremy Rowland » Fri May 10, 2024 9:56 pm
Some half decent weather at last! :D I got up to my machines earlier this week, I did have one other previous visit where I did a small amount of cosmetic work on the Poclain. As many of you will no doubt be aware keeping machines outside they get covered in muck without doing any work, the 580BT looks rather weather beaten these days and was covered in a layer of muck that needed washing off.
I quickly got to work washing the machine down and the weather was perfect for this to be done, although we have had a few days of dry weather I didn't want to track either machine through mud to wash it off only to find it covered back in mud after I had tracked it back.
I do have a few days holiday due to me now so I need to get moving with some serious work, the Poclain also got another clean down.
Has thanked: 974 times
Been thanked: 795 times
Post #193 by essexpete » Fri May 10, 2024 11:27 pm
Brightening up J!
Post #194 by Jeremy Rowland » Sat May 11, 2024 7:47 pm
essexpete wrote:Brightening up J!
At long last! :thumbup:
Post #195 by Jeremy Rowland » Fri May 29, 2026 11:19 pm
Work has temporarily halted on the 690 for a couple of reasons, I'm still waiting on my fabricator to make the other panels I require and I still need to get three new hinges made, that aside I have turned back to do some more work on the 580BT. The side window rail where the two sliding windows are has rotted away, hardly surprising when you consider the machines age, I cleaned this up, got rid of the rotted metal and bolted a new strip of metal into place.
I considered if I should free off the sliding windows but after some serious consideration, I remembered all too well the horrible rattling noise they make when the engine is on tick over so I left well alone.
Post #196 by Jeremy Rowland » Fri Jul 17, 2026 7:40 pm
Work has continued on the 580BT and with the heatwave we've all been experiencing, I couldn't resist turning it into a cabriolet :o :lol: yes one of the very first repairs I carried out on this machine back in 2015 was a temporary repair to the cab roof which had started to fail due to the continual rust. I have found another fabricator, although my other one has finally come up trumps with the new panels for the 690.
With osome help from Andrew's mechanic, the old cab roof was cut off and the new one installed, the fabricator had made this from the pattern that CMN member Norman Orrick made for me some time back now, so spot on Norm :claphands:
The only downer was one of the two sliding windows shattered, whether from heat or sparks I don't know, but the decision has now been made that I will get the other window removed and a new single large one fitted, it does not trouble me that this will be none standard, these windows never slid as they were supposed to used to make one hell of a racket when the engine was on tickover, and let rainwater in to the cab, so good ridance so far as I am concerned, the roof will be repainted all being well on my next visit, I only made sure the bare metal was covered before I left. :thumbup:
Post #197 by essexpete » Sun Jul 19, 2026 12:18 am
Well done Jeremy and not forgetting Norm!
Post #198 by Jeremy Rowland » Sat Sep 12, 2026 9:26 am
Finally I managed to get back to continue some of the restoration work, it's never ending :lol: The cab on the BT is not in the best of condition, okay so the roof is now fixed, the next job was cab side behind the door along with the door rail. Once again much thanks goes to Tony Wilson who assisted me to get this job done, it was easier to remove the cab door, and side glass then cut the old panel out which had only rotted badly at the base, and weld a new piece of steel into replace it.
This was a full days work and there is more to do as well which I am hoping to press on with next visit, the door rail still needs fitting but that is a formality. :thumbup:
Return to “Excavators”
