JCB 3C II 1973 Engine serial No. 6797 Leyland 4/98NT.
How to replace Fan belt, remove hydraulic pump/just unbolt from pulley?
Thanks David
JCB 3C II 1973 replace Fan Belt
- Has thanked: 971 times
- Been thanked: 794 times
Re: JCB 3C II 1973 replace Fan Belt
It is many years since I changed a fan belt on a 3C, but I think if you can remove the bolts holding the shaft to the crank pully, you can get enough space by sliding the shaft on the splines. It is a bit of a pig if I remember correctly. Some tie back a spare belt at the same time. I found that a waste of time as the couple of times I did that, the belt was either rubbed or oil contaminated.
