Hymac 690
Discuss excavators here
Has thanked: 2096 times
Been thanked: 1877 times
Re: Hymac 690
Post #161 by Jeremy Rowland » Thu Feb 19, 2026 9:39 pm
I did run the 690 today as well. :thumbup:
Has thanked: 980 times
Been thanked: 801 times
Re: Hymac 690
Post #162 by essexpete » Fri Feb 20, 2026 7:44 pm
Need a bucket for the open day!
Re: Hymac 690
Post #163 by Jeremy Rowland » Sat Feb 21, 2026 7:07 pm
essexpete wrote:Need a bucket for the open day!
I think she needs a bit more than that Pete :lol: :lol: I am planning on starting some more resto work on her as soon as I can, just not quite sure where to start next. :D
Re: Hymac 690
Post #164 by Jeremy Rowland » Fri Apr 17, 2026 9:42 pm
I have restarted work on this long term expense, er I mean project :oops: I have sent some patterns off (old panels lent to me) to a local fabrication company who made the two panels for the other side of the machine, I need to get some new hinges made, I have located a manufacturer so I needed to get the one good hinge removed, check the other was the same size and measure up for the one on the other side of the machine.
Having removed the panel, I had to cut the tack welding to remove the hinge, it is the same size for the other panel on the same side of the machine which is missing, the hinge on the other side is longer. I fitted two bolts to hold the panel in place until I'm ready to fit the new panel and hinge which will take longer than anticipated due to the fabricator who I spoke with today, he is stacked out with work and cannot get any skilled men :thumbdown: oh well will have to modify my plans perhaps.
Managed to rub down the engine stop and throttle cable holding assembly and prime that so a good days work in all, think I need to learn some fabrication skills and quickly. :think: :lol:
Return to “Excavators”
