I wonder if anyone can advise. This is an original KX41, not a -2 or -3, probably mid '90s and with D1105 engine.
Mice have eaten one of the cooling hoses part 060 in the attached screenshot. This part is no longer available.
However I wonder if I even need it. The mouse hose 060 from the radiator and hose 040/050 from the engine bother connect to a block 080 which provides a convenient drain point. If that's the only function, could I just bypass that part and connect radiator spigot to engine spigot with a bit of plain hose? Or blank off both spigot?
Or would this mess up water flow in some way?
Thanks, Tony S
Kubota KX41 Digger Cooling Hoses
- Has thanked: 1888 times
- Been thanked: 1704 times
Re: Kubota KX41 Digger Cooling Hoses
Hi Tony and welcome
you could try that the best way to find out is use a temporary blank until you are sure that the engine does not overheat, alternatively there are hose manufacturers out there who could provide a hose of a similar diameter and you may have enough room to bend it round? Hope that helps.
- Real name: ian
- Has thanked: 126 times
- Been thanked: 117 times
No direct experience and only going from the diagram, I would have no problem bypassing "80" and going direct.
It's possible these ports are provided for when a heater is fitted.
I'd be careful blanking a port high on the block/head in case it's needed to clear air from the cooling system or maintain some circulation when the thermostat is closed.
Using a single hose to replace "40 & 60" looks a good option.
Thanks. I ran a temporary hose between the two just to check for no leaks elsewhere. There's some mouse damage on the main lower hose but I "think" its only beyond the hose clips, it's difficult to inspect.
Unfortunately I now have a leaking injector so have to sort that out before dealing with cooling system, earlier I didn't spot the Diesel leakage with all the water being sprayed around.
