hi all ,
was looking at the heavy haulage section and found this picture by neversweat steve , what do you reckon gentleman ??
something different ???
Topic author - Posts: 196
- Real name: steve
- Has thanked: 18 times
- Been thanked: 73 times
Re: something different ???
When the test track at the Toyota factory at Burnaston was being constructed they used a roller which was pulled up and down the banking by a winch on a dozer. The paver was a special one built for the task, it travelled around the banking but the drivers seat and engine etc was upright so that the operator was always in the normal sitting position, it looked strange when it was sitting on level ground! The material (wet mix from Tilcon at Ballidon and coated from RMC at Washwood Heath) was taken by elevator to the paver. It must have been a well paying job as the paver was built especially for that one job.
Pete.
Pete.
- Real name: neil c
- Been thanked: 3 times
ruston wrote:When the test track at the Toyota factory at Burnaston was being constructed they used a roller which was pulled up and down the banking by a winch on a dozer. The paver was a special one built for the task, it travelled around the banking but the drivers seat and engine etc was upright so that the operator was always in the normal sitting position, it looked strange when it was sitting on level ground! The material (wet mix from Tilcon at Ballidon and coated from RMC at Washwood Heath) was taken by elevator to the paver. It must have been a well paying job as the paver was built especially for that one job.
Pete.
Hello Pete ,did you ever run material to Tilcons job at MIRA ? off the A5 near Nuneaton where because of the gradients they apparently bolted two BKs together while surfacing the test track ,that would be back in the 90s. Never saw it myself so don"t know how much truth is in that bit of folklore. Regards Neil
neilc wrote:Hello Pete ,did you ever run material to Tilcons job at MIRA ? off the A5 near Nuneaton where because of the gradients they apparently bolted two BKs together while surfacing the test track ,that would be back in the 90s. Never saw it myself so don"t know how much truth is in that bit of folklore. Regards Neil
We did a fair bit at MIRA over the years Neil, though our quarry at Mancetter (Atherstone) was only a few miles away so they did more. I cannot recall two machines fastened together but the we didn't get involved much in the banking jobs as granite was normally used, however one of Mancetter's Fodens fell on its side on the banking. I remember going around the banking in a laden eight wheeler, I was following the roller and paver so was only going slowly and it was pretty scary I can tell you! The banking at Toyota WAS steep, we were told that 60mph minimum was needed to keep a car on it.
We also surfaced the test tracks at Gaydon and the Lucas/Girling one at Fen End near Solihull.
Pete.
- Real name: neil c
ruston wrote:neilc wrote:Hello Pete ,did you ever run material to Tilcons job at MIRA ? off the A5 near Nuneaton where because of the gradients they apparently bolted two BKs together while surfacing the test track ,that would be back in the 90s. Never saw it myself so don"t know how much truth is in that bit of folklore. Regards Neil
Pete.
Hello Pete ,I know what you mean , I did quite a lot of work at the Millbrook circuit in Bedfordshire some years back , some of the gradients maybe 1 in 10 or less and savage crossfalls on severe curves you think you are going to tip clean over , really does focus the mind ! By the way Pete who manufactured the paver for the Toyota job ? Regards Neil
- Real name: Richard
- Has thanked: 530 times
- Been thanked: 177 times
Good stuff Steve,
Is it a giant extruder curb machine![Laughing :lol:](./images/smilies/icon_lol.gif)
Neil, i worked at Millbrook a few times over the years, i once went round in a Foden low loader with all the kit on the back, It sure made your ar_e grip the seat!!
Hi Steve,
I also found this that Neversweat Steve has posted.
I recognise the Alberet PTR,s but not the machines, Dynapacs maybe, any ideas guys?
neilc wrote:Hello Pete ,I know what you mean , I did quite a lot of work at the Millbrook circuit in Bedfordshire some years back , some of the gradients maybe 1 in 10 or less and savage crossfalls on severe curves you think you are going to tip clean over , really does focus the mind ! By the way Pete who manufactured the paver for the Toyota job ? Regards Neil
Hi Neil, alas I cannot recall the manufacturer and of course in those days (about a dozen years or more ago) I didn't carry a camera with me! It was painted yellow if that helps!!!
![Wink ;)](./images/smilies/icon_e_wink.gif)
Just seen this on Youtube, not the same sort of machine but still interesting. I wonder about engine lubrication? http://www.youtube.com/watch?v=DshG_XG_fJY
Pete.
- Real name: steve
