Hi, I'm looking for any info on an Aveling Barford Diesel Roller, the model type is GDR
It's been lying in our yard for years, and I'm currently trying to get it sorted up to try and get it running again. Been squeezing some time between work to change oil, sort out the fuel system, belts and hoses etc, a mechanic is going to come up when its ready to try and fire up.
Aveling Barford Roller
- Real name: Julian
- Been thanked: 13 times
Re: Aveling Barford Roller
Hi there, it's looking too good for the scrap-man. What engine does it have?
Julian.
Julian.
Julian wrote:Hi there, it's looking too good for the scrap-man. What engine does it have?
Julian.
4 Cylinder Ford engine Julian
- Real name: steve
- Has thanked: 18 times
- Been thanked: 73 times
this is great !! do keep us informed with progress updates , be a good picture along with m.howes when he finds a pf 90 bk ! lol
That looks like a great project
They were fitted with a sliding counter weight to alter the pressure applied by the rolls.
The GD range are the largest in the G range, I have a GA type roller , G stands for Grantham and the letters A to D denotes machine size.
The engine in these were pretty good but can have block damage if anti freeze was not used.The cab doors were a large glass panels.
Hopefully the linkages and brakes are not too bad for you.
Looking forward to seeing your progress.
- Real name: Julian
B100 LOADER wrote:That looks like a great project![]()
That's interesting and a new one on me. Would you care to explain a little more, please!
Julian.
Hello Julian
Steam rollers used their dead weight to compact tarmac.Diesel rollers could be ballasted using water to make them heavier than their normal road weight.Some of the larger Aveling diesel rollers had a heavy metal weight that can be moved towards the front of the roller to redistribute the weight from the rear rolls to the front.This weight was hand cranked using a handle to move the weight on a trolley type contraption.When the roller was used to scarify the road the weight would be further back therfore putting more weight on the rear rolls.My little Ga roller has plugs on the front rolls to be removed and filled with water ballast if required.
As you know these days,rollers are fitted with vibrating rolls to increase compaction.
The metal weight is situated below the cab on the roller base frame between the rear of the machine and the transmission.I guess its travel would be around 4 or 5 foot
Hope this answers your question ? I have got an operating manual somewhere,will scan a photo of the rollers internal workings .
Would like to see more about the weight transfer idea, I've not really looked under the floor panels yet.
- Real name: Julian
B100 LOADER wrote:Hello Julian
I've been looking at the picture of that GD and it's difficult to see just where this moveable weight lives, it must be low down I guess. Also I wonder why they just didn't fill the space entirely with solid weight and add to the total effectiveness of the roller, though maybe they didn't want too much on the rear rolls when rolling tarmac as I guess you'd make tramlines in the surface too easily?
Anyway, out of interest, I've got an Aveling DX8, but there doesn't seem to be any provision for water ballasting the rolls - I'll go and have a look and check again, I guess there will be some sort of bung on the things.
Julian.
