HI,
Hoping that some one can help me I have a PH2 in my dumper on the dip stick there is only one mark on it is this the min level or max?
My PH1 has 2 marks on stick is easy to get right.
Thank you.
PH2 oil level
Re: PH2 oil level
womble3go wrote:HI,
Thank you.
Kevin as a general rule if there is only one mark on the stick then it is the maximum mark hope that answers your question.
- Real name: John
- Has thanked: 302 times
- Been thanked: 138 times
Re: PH2 oil level
G'Day Kevin, If you have a manual on your engine then next oil change fill it up with the correct amount of oil less 1 litre or pint and insert the dip stick. This can then be permanently marked using a hacksaw and will be your minimum level. Then pour in the rest and it should be on you existing line if all goes well.
Topic author - Posts: 27
- Real name: kevin
- Been thanked: 4 times
Re: PH2 oil level
Thank you for these reply's, I like the one of under filling then putting in the second mark, so will go for this.
Kevin.
Kevin.
Re: PH2 oil level
The PH1 & 2 Should have the same dipstick.
The crank case casting of the PH1 is only a shorter version of the PH2 casting.
Everything else including the dipstick has the same dimension so just mark the one dipstick agsinst the other.
The part Nos of both sticks are the same.
