JCB Crawler Excavator 208 1983-86 model
Topic author - Posts: 49
- Real name: Charlie
- Has thanked: 12 times
- Been thanked: 15 times
Re: JCB Crawler Excavator 208 1983-86 model
Very productive day spent in the workshop on Saturday. Bucket, dipper and boom ram seals done so no more leaks. Then moved onto the track which needed to loose a link. By god the pins were tight so made up a jig to push them out. Was still just on the limit of the 10 ton ram.
Next job was to reset the track tension ram and replace the top roller bearings. Then re-attach the track and tension correctly.
While I was on a roll I thought I'd look at the other side roller bearing. What the frig!!!!!! There was no bearing and the track had been cutting grooves in it!
Only solution for now, weld up the grooves, turn best i can on the lathe, new bearings and hope it works! Ok it's not perfect but hey, it works for now. I call that Charlie-6 JCB-0. Not a bad day
- Has thanked: 1875 times
Nice one Charlie having access to a lathe and welding equipment all helps with resto jobs, plus the skills too and not forgetting the little helper.
- Real name: Paul Griffiths
- Has thanked: 384 times
- Been thanked: 256 times
thats the go steady steady dont get to much on the go like I do and end up with nothing finished
nothing wrong with welding up a roller there is some special grade of rod thats meant to be used according to the experts Im not real sure what it is but I reckon what ever you used will be just fine
Track pins always take a lot of pushing to get out well done done mate
happy little worker still on the job
great stuff and keep it coming
